Help needed with GPS project SOLVED!
Hi Guys;
I have a project that is using a GPS receiver and I am lost with some of the commands.
My issue is getting the latest data from the GPS and updating the variables for my program.
I am after SPEED, Course, Altitude and Quantity of Satellites.
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
TinyGPSPlus gps;
SoftwareSerial GPS(8, 7);
const char UBLOX_INIT[] PROGMEM = {
  0xB5, 0x62, 0x06, 0x08, 0x06, 0x00, 0x64, 0x00, 0x01, 0x00, 0x01, 0x00,
  0x7A, 0x12,0x12, 0xB5, 0x62, 0x06, 0x08, 0x00, 0x00, 0x0E, 0x30,};  //(Set GPS to Read at 10Hz)
float Dir, S, SK, SM;
void setup(){
    GPS.begin(9600);
for (int i = 0; i < sizeof(UBLOX_INIT); i++) {
    GPS.write( pgm_read_byte(UBLOX_INIT + i) );
    delay(5);}}
int C;
int Alt;
int AltM;
int AltF;
int Sat;
void loop(){
    while (GPS.available() > 0)
if (gps.encode(GPS.read()))
if (millis() > 5000 && gps.charsProcessed() < 10){
    while(true);}
if (gps.speed.isValid()){
    SK =  (gps.speed.kmph());                                         // Read Speed in KM/H
    SM =  (gps.speed.mph());}                                         // Read Speed in MPH
if (gps.altitude.isValid()){
    AltM= gps.altitude.meters();                                      // Read Altimeter in Meters
    AltF= gps.altitude.feet();}                                       // Read Altimeter in Feet
if (gps.course.isValid()){
    Dir = gps.course.deg();}                                          // Read Course Direction
if (gps.satellites.isValid()){
    Sat = gps.satellites.value();}                                    // Read Satellite Quantity
if (digitalRead(5) == LOW){
    S = SK;
    Alt = AltM;
    Serial.print(S);                                                  // Speed in KM/H
    Serial.println(F(" KM/H"));
    Serial.print(Alt);                                                // Altimeter in Meters
    Serial.println(F(" M Alt"));}
if (digitalRead(5) == HIGH){
    S = SM;
    Alt = AltF;
    Serial.print(S);                                                  // Speed in MPH
    Serial.println(F(" MPH"));
    Serial.print(Alt);                                                // Altimeter in Feet
    Serial.println(F(" F Alt"));}
//  SERIAL PRINT VALUES
    Serial.print(Dir);                                                // Show Course Direction
    Serial.println(F(" Dir"));
    Serial.print(Sat);                                                // Show Satellite Quantity
    Serial.println(F(" Sats"));
    Serial.println(" ");
The problem I am seeing is that the data is not updating any ware close to real time or accuracy.
what am I doing wrong?
Thanks
Rick
If the module doesn't have a clear view of the sky, the measurements won't be updated from time to time.
TinyGPS++ has a function to read the "age" of the most recent update, so you can decide whether the measurements are still useful.
I don't believe it is having trouble seeing the satellites as i have another program that displays the data just fine. But it dosent show all the data i need.
Rick
Check the age and then you can be sure. You don't need to convince me of anything.
When I see your code - it looks like you miss a curly bracket (the { )
Your code is this:
    while(true);}
For a better view, it looks like this (symbolic):
WHILE ()
    if (A)
        if (B) { ... }
All the rest of code is "outside" your WHILE ! Your WHILE() has just two IF()s, which are "nested".
Are you sure the code is right?
For me it looks like, you miss curly brackets.
I will check that out shortly. Hopefully, that is my issue!
Rick
tjaekel, preliminary testing looks like that was the issue. I will fully test it out tomorrow in the car
and let you know.
Thanks,
Rick
tjaekel, that did it! Thank you so much!
Rick
Hint.
Do a press [ CTRL ] [ T ] when you edit your code and check the { and } indenting, that way you could have possibly found it earlier.
Tom... :smiley: :+1: :coffee: :australia:
COOL! Well done.
Happy coding...!
Torsten (tjaekel)
