I've researched this extensively and still can't solve it.
I am trying to write a sketch that will take an analogue reading every 100ms over two minutes and at the end send the collection of data to a file via ftp.
Ideally, the ftp file will look like "400;401;309;.... etc
My problem is with converting the integer value from A0, then concatenating with ";" to produce a single string as shown above.
Thanks for the replies. The ftp process writes a file to my WD myCloud nas device. It takes about 1 second to complete so I need to collect the data first and transfer it as one set when complete.
What I'm looking for is:-
take a reading (as integer)
convert to char
add ";" to separate the values
repeat the above, say 200 times at 100ms intervals.
When complete, send the data by ftp.
Thanks again.
So, will whatever Arduino you're using(?) have enough RAM to hold a buffer 120 * 10 * 5 plus whatever overhead you need for this string you're building? Are you pre-allocating the whole buffer, or using something like String+ to append? Could you send it in smaller blocks?
Maybe if you show us your code so far, we'll have a better understanding of where your problem lies.
You don't need to do that . Building the String as you go is memory intensive, you could delay that to later.
You could Loop to acquire your samples every 100ms over 2 minutes and store them in RAM (2400 bytes, so you'll need an somewhat capable Arduino, not an UNO or Nano).
once you have acquired the 1200 samples you open your FTP channel and dump the data
here is how this could work, dumping the data on the Serial monitor
constexpr unsigned long samplePeriodMs = 100ul; // Sampling period in milliseconds
constexpr unsigned long durationMs = 5000ul; // use 120000ul for 2 minutes (Total duration (2 minutes in milliseconds))
constexpr size_t sampleCount = durationMs / samplePeriodMs; // Total number of samples
uint16_t samples[sampleCount]; // Array to store samples in RAM
Serial.println("Starting sampling...");
unsigned long startTime = millis();
for (size_t i = 0; i < sampleCount; i++) {
samples[i] = analogRead(A0); // Acquire sample from A0
delay(samplePeriodMs); // Wait for next sample time
Serial.println("Sampling complete.");
Serial.println("Sampled data:");
for (unsigned int i = 0; i < sampleCount; i++) {
Serial.print(samples[i]); // Print each sample to Serial
if (i != sampleCount-1) Serial.write(','); // add the comma where needed
Serial.println(); // terminate by a new line
void loop() {}
(this code would only run for 5 seconds, so acquiring 50 samples if you don't want to wait for 2 minutes).
Thanks a lot but I should have said that the device will be operating well away from any computer so serial output is no use. Yes, I need to check available RAM on the esp8266
Apologies.
I've so many sketches on this, need to sort out a sensible one and post it here.
Instead of dumping the data to the Serial stream, just dump it iteratively into the FTP stream (libraries have ways to write to the output) and then close the stream.
an ESP8266 should be fine, you need to find a good FTP client library for it. (I don't use the 8266 anymore, there are FTP clients for ESP32)
Ah yes. I'm using FTPClient_Generic. When I timed the ftp process it included the opening and closing functions. This took about 1 second, clearly the write process alone will be so much quicker.
Thanks for all your help, I'll get cracking now. The end is in sight!
// 2024-10-28
#include <ESP8266WiFi.h> // Include the Wi-Fi library
#include <FTPClient_Generic.h>
char ftp_server[] = "192.168.1.101";
char ftp_user[] = "esp8226";
char ftp_pass[] = "XXXXX";
char dirName[] = "meters";
char newDirName[] = "/home/ftp_test/NewDir";
FTPClient_Generic ftp (ftp_server, ftp_user, ftp_pass, 60000);
char fileName[] = "flashtest01.txt";
const char* ssid = "XXXX"; // The SSID (name) of the Wi-Fi network you want to connect to
const char* password = "XXXXXX"; // The password of the Wi-Fi network
const int analogInPin = A0; // ESP8266 Analog Pin ADC0 = A0
int timer1 =10000; //10 seconds
char tmp [5];
while (!Serial); // wait for Serial Monitor to open
WiFi.begin(ssid, password); // Connect to the network
Serial.print("Connecting to ");
Serial.print(ssid); Serial.println(" ...");
while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
Serial.print('.');
Serial.println('\n');
Serial.println("Connection established!");
Serial.print("IP address:\t");
Serial.println(WiFi.localIP()); // Send the IP address of the ESP8266 to the computer
ftp.OpenConnection();
ftp.ChangeWorkDir(dirName); //Change directory
ftp.InitFile(COMMAND_XFER_TYPE_ASCII); // Create a new file to use as the download example below:
ftp.AppendFile(fileName);
while (timer1 > 0){
int val = analogRead(analogInPin);
sprintf (tmp, "%d;", val);
ftp.Write(tmp);
--timer1;
delay(100);
ftp.CloseFile();
Serial.println("Done");
delay(10000);
