Help needed with MPR084
I need some working sample code to get me started with the MPR084 capacitive touch sensor IC.
I googled, tried every piece of code I saw, but I can get no reliable response from the little bugger.
That suggests to me that you have hardware problems rather than software ones. What is your setup? Are you using a PCB? You need to in order to get a consistent response from a capacitive touch sensor.
Yes, it is all on a small PCB with connectors, I have included the schematic.
http://files.jeelabs.org/2010/02/Screen-shot-2010-02-14-at-12.05.27.png
The sensorplate I use is a piece of copper foil of 3 x 1 cm connected thru a short wire to pin 3 (E1 of MPR084) of SV1. A short cable connects PORT1 to my Arduino.
I just need an example how to configure the registers to activate one or more sensors and how to read them.
Anyone?
This is an I2C device so you must connect it to the arduino's I2C pins (A4 & A5). You also need a 4K7 pull up resistor on each of these lines. Have you done this?
Then look at the I2C tutorials to see what libraries you need.
http://www.arduino.cc/playground/Learning/I2C
Then follow the data sheet to set up the registers.
This is a 3.6V device I hope you are not using it with a 5V arduino.
