Help needed with my Hall sensor driven Tachometer
Hi, so recently I've tried to make my own Tachometer project. I am using Arduino Uno, A3144 Hall-effect sensor and 1.8' TFT display for displaying the RPM value. The only minor problem I am seeking to resolve right now is the jump in value. So for example when the sensor isn't detecting any magnetic field the value is 0 but after just one detection the value immediately jumps to 60 rpm. How can I edit the code so the value goes up gradually and not by segments of 60(0,60,120,180...)? Any help is much appreciated.
#include <TFT.h>  // Arduino LCD library
#include <SPI.h>
// pin definition for the Uno
#define cs   10
#define dc   9
#define rst  8
// create an instance of the library
TFT TFTscreen = TFT(cs, dc, rst);
// char array to print to the screen
char sensorPrintout[4];
int hallsensor = 2;                // Hall sensor at pin 2
volatile int counter;
unsigned int rpm;
unsigned long passedtime;
void isr()
   //Each rotation, this interrupt function is run twice, so take that into consideration for
   //calculating RPM
   //Update count
      counter++;
 {Serial.begin(9600);
   //Intiates Serial communications
   attachInterrupt(0, isr, RISING); //Interrupts are called on Rise of Input
   pinMode(hallsensor, INPUT); //Sets hallsensor as input
   counter = 0;
   rpm = 0;
   passedtime = 0; //Initialise the values
   // Put this line at the beginning of every sketch that uses the GLCD:
  TFTscreen.begin();
  // clear the screen with a black background
  TFTscreen.background(0, 0, 0);
  // write the static text to the screen
  // set the font color to white
  TFTscreen.stroke(255, 255, 255);
  // set the font size
  TFTscreen.setTextSize(2);
  // write the text to the top left corner of the screen
  TFTscreen.text("Sensor Value :\n ", 0, 0);
  // ste the font size very large for the loop
  TFTscreen.setTextSize(5);
   delay(999);//Update RPM every second
   detachInterrupt(0); //Interrupts are disabled
   rpm = counter*60;
   passedtime = millis();
   counter = 0;
   Serial.print("RPM=");
   Serial.println(rpm); //Print out result to monitor
   attachInterrupt(0, isr, RISING);   //Restart the interrupt processing
    // Read the value of the sensor on A0
  String sensorVal = String((rpm));
  // convert the reading to a char array
  sensorVal.toCharArray(sensorPrintout, 4);
  // print the sensor value
  TFTscreen.text(sensorPrintout, 0, 20);
  // wait for a moment
  delay(250);
  // erase the text you just wrote
  TFTscreen.stroke(0, 0, 0);
Check your counter more frequently. Try every five seconds to start with perhaps.
Measuring such slow rotation I suggest to measure the time between pulses, the time for one revolution. Then do the math. something like: revs/ second == 60 * revs / measured time -> RPM
The code in this link is derived from a program I was using to control the speed of a small DC motor. It records the time of each pulse.
...R
