I recently got into arduino coding and want to build an rc car using nrf24l01 module.
I refered to a lot of tutorials and tried a lot of codes but the 2 arduinos' wont communicate.
i tried this code
/*`Preformatted text`
If your serial output has these values same then Your nrf24l01 module is in working condition :
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x03
CONFIG = 0x0f
This code is under public domain
Last updated on 21/08/28
https://dhirajkushwaha.com/elekkrypt
#include <SPI.h>
#include <RF24.h>
#include <printf.h>
RF24 radio(7, 8);
byte addresses[][6] = { "1Node", "2Node" };
pinMode(6, OUTPUT);
digitalWrite(6, HIGH);
radio.begin();
radio.setPALevel(RF24_PA_LOW);
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1, addresses[1]);
radio.startListening();
printf_begin();
radio.printDetails();
// empty
and i got this reciever :
RX_ADDR_P0-1 = 0x65646f4e31 0x65646f4e32
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0x65646f4e31
RX_PW_P0-6 = 0x20 0x20 0x20 0x20 0x20 0x20
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x03
CONFIG = 0x0f
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1 MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_LOW
ARC = 0
transmitter :
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x03
CONFIG = 0x0f
Data Rate = 1 MBPS
Model = nRF24L01+
PA Power = PA_LOW
ARC = 0
BUT , when i tried this code in transmitter
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
// Instantiate RF24 class with CE and CSN values
RF24 radio(7, 8);
// Address to devices comunicate each other (same in both)
const uint64_t pipe = 0xE8E8F0F0E1LL;
// A variable to hold some info
boolean info = false;
// Setup serial output
// Start RF
radio.begin();
// Setup the channel to work within, number 100
radio.setChannel(100);
// Open wite pipe
radio.openWritingPipe(pipe);
// it changes every interval
info = !info;
if (info) {
Serial.print("Sending positive... ");
Serial.print("Sending negative... ");
// Send info over RF
bool success = radio.write(&info, sizeof(boolean));
if (success) {
Serial.println("sent!");
Serial.println("fail!");
// Wait 2 seconds and repeat
delay(2000);
Then the serial moniter was:
Sending positive... sent!
Sending negative... fail!
Sending positive... fail!
reciver code :
#include <SPI.h>
#include "RF24.h"
RF24 radio(7, 8);
// Start RF
radio.begin();
// Open recept pipe
radio.openReadingPipe(1, pipe);
// Start to listen
// Wait until some data
if (radio.available()) {
Serial.println('A');
// Read payload, and check if it finished
radio.read(&info, sizeof(info));
// Manage info
if (info) {
Serial.println("We received positive!");
Serial.println("We received negative!");
// Wait a bit
delay(50);
reciever serial monitor shows nothing
So Pls help me
