Can anyone tell me what I am doing wrong? I have an Arduino Duemilanove sketch running, which correctly outputs data as follows.
Arduino serial monitor output (typical values) - 656 656 656 658 656 656 656 657 656 655 657
I am using the following readString() example from the processing reference -
// Example by Tom Igoe
import processing.serial.*;
Serial myPort; // The serial port
void setup() { // List all the available serial ports: println(Serial.list());
// I know that the first port in the serial list on my mac // is always my Keyspan adaptor, so I open Serial.list()[0]. // Open whatever port is the one you're using. myPort = new Serial(this, Serial.list()[0], 9600); }
void draw() { while (myPort.available() > 0) { String inBuffer = myPort.readString(); if (inBuffer != null) { println(inBuffer); } } }
The problem is that blank lines are sometimes inserted, and the string is sometimes split into two lines, as shown below.
The processing output window -
Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 [0] "COM3" 658 658 658
658 659 658
658 659 659
657 659 660
659 658 655 6 59 659 659 6 59 659 656 65 9
Thanks in advance!
