Help needed with program
This is my first post on the Arduino forums so please be kind. I am trying to make this project https://www.instructables.com/id/Star-Track-Arduino-Powered-Star-Pointer-and-Tracke/ . I have printed the frame and built the electronics but am strugling with the software. I have installed the required libraries and the ide compiles without any errors but i am not getting any readout in the serial monitor. I have tested the MPU6050 with another program and it reads fine. Could anyone with more knowledge have a look at the master software and see if there is a problem with it. Many thanks.
If you post here the exact software that you are using (as described in "Read this before posting a programming question"at the top of the forum) then probably. But I don't think we want to go wandering round the internet trying to work out what you might be doing and what might have gone wrong with it.
Steve
 This is the source code for the master-module of Star Track.
 Required Libraries:
 https://virtuabotix-virtuabotixllc.netdna-ssl.com...
 https://github.com/jrowberg/i2cdevlib/zipball/mas...
 Created 20 July 2016 by Görkem Bozkurt
#include <virtuabotixRTC.h>
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
//define RTC.
virtuabotixRTC myRTC(A0, A1, A2);
double M,Y,D,MN,H,S;
double A,B;
double location =32.88;//your longtitude
double LST_degrees;//variable to store local side real time(LST) in degrees.
double LST_hours;//variable to store local side real time(LST) in decimal hours.
unsigned long timer = 0;
float timeStep = 0.01;
// Pitch and Yaw values
double pitch = 0;
double yaw = 0;
double val = 0;//variable to store the user input DEC
double val2 = 0;//variable to store the user input RA
double temp = val2;//temporary value to store val2
const int stahp=7,stahp2=10;
const int cw=8,cw2=11;
const int ccw=6,ccw2=9;
    //set date-time according to (seconds, minutes, hours, day of the week, day of the month, month, year)
    myRTC.setDS1302Time(00, 38, 23, 5, 27, 7, 2016);
    pinMode(stahp,OUTPUT);
    pinMode(cw,OUTPUT);
    pinMode(ccw,OUTPUT);
    pinMode(stahp2,OUTPUT);
    pinMode(cw2,OUTPUT);
    pinMode(ccw2,OUTPUT);
    delay(5000);//wait before starting
    while(!mpu.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G))
    mpu.calibrateGyro();
    mpu.setThreshold(3);
}//--(end setup )---
    //this will update the RA degrees with sidereal time 1degree at a time
    //this way the object or star on the sky is tracked.
    if( floor(LST_degrees)==LST_degrees ){
      if (LST_degrees>180){
        val2 = temp+(360-LST_degrees);
        }else{
        val2 = temp-LST_degrees;
    myRTC.updateTime();
    LST_time();
    recvdata();
    pitch_check();
    yaw_check();
    timer = millis();
    Vector norm = mpu.readNormalizeGyro();
    //I've put the sensor with a 90 degree angle on the setup due to
    //cable connection problems. Because of that the data values from the mpu6050 chip are
    //different in this case:
    //roll data(X-axis) is pitch.
    //pitch data(Y-axis) is yaw.
    yaw = yaw + norm.YAxis * timeStep;
    pitch = pitch + norm.XAxis * timeStep;
    Serial.print(" Yaw = ");
    Serial.print(yaw);
    Serial.print(" Pitch = ");
    Serial.print(pitch);
    Serial.print(" LST_d = ");
    Serial.print(LST_degrees);
    Serial.print(" LST_h = ");
    Serial.println(LST_hours);//local sidereal time in decimal hours.
    delay((timeStep*1000) - (millis() - timer));//timer for the gyro.
void recvdata(){
  //This function receives data from serial as (0.00,0.00)
  //splits it to strings by the comma ","
  //than converts them to doubles
    if (Serial.available() > 0){
        String a= Serial.readString();
        String value1, value2;
        // For loop which will separate the String in parts
        // and assign them the the variables we declare
        for (int i = 0; i < a.length(); i++) {
            if (a.substring(i, i+1) == ",") {
                value2 = a.substring(0, i);
                value1= a.substring(i+1);
        val=90-value1.toFloat();
        val2=value2.toFloat();
        temp = val2;
void pitch_check(){
    //check if pitch is high, low or equal to the user input
    //send commands to slave-module to start and stop motors
    if(floor(pitch*100)/100==floor(val*100)/100){
        digitalWrite(stahp,HIGH);
        }else{
        digitalWrite(stahp,LOW);
    if(floor(pitch*100)<floor(val*100)){
        digitalWrite(cw,HIGH);
        }else{
        digitalWrite(cw,LOW);
    if(floor(pitch*100)>floor(val*100)){
        digitalWrite(ccw,HIGH);
        }else{
        digitalWrite(ccw,LOW);
void yaw_check(){
    //check if yaw is high, low or equal to the user input
    if(floor(yaw*100)==floor(val2*100)){
        digitalWrite(stahp2,HIGH);
        }else{
        digitalWrite(stahp2,LOW);
    if(floor(yaw*100)<floor(val2*100)){
        digitalWrite(cw2,HIGH);
        }else{
        digitalWrite(cw2,LOW);
    if(floor(yaw*100)>floor(val2*100)){
        digitalWrite(ccw2,HIGH);
        }else{
        digitalWrite(ccw2,LOW);
void LST_time(){
    //Calculates local sidereal time based on this calculation,
    //http://www.stargazing.net/kepler/altaz.html
    M = (double) myRTC.month;
    Y = (double) myRTC.year;
    D = (double) myRTC.dayofmonth;
    MN = (double) myRTC.minutes;
    H = (double) myRTC.hours;
    S = (double) myRTC.seconds;
    A = (double)(Y-2000)*365.242199;
    B = (double)(M-1)*30.4368499;
    double JDN2000=A+B+(D-1)+myRTC.hours/24;
    double decimal_time = H+(MN/60)+(S/3600) ;
    double LST = 100.46 + 0.985647 * JDN2000 + location + 15*decimal_time;
    LST_degrees = (LST-(floor(LST/360)*360));
    LST_hours = LST_degrees/15;
I am using 1.8.5 to load and view the serial monitor.
Rutgar:
and you have the BAUD rate set to 115200 ? (as it is in your sketch)
Yes and have tried different baud rates as well
You should put a few lines such as
Serial.println("Hello 1");with varying values for the number, all along your code, beginning just after the Serial.begin, to see if you can get some printout at some time of never.
