Help needed with setting up elctronic circuit
I have no background of electronics or anything like that. My project is making a small model of house and making it controlable with a smartphone, my code for this is completed but like I said I have no clue how to make the elctronics.
the circuits needs 5 Leds and 3 DC motors, If someone could help me making a sketch how to make this or give me some tips that would be awesome
PS: I’m using an MKR1000 Arduino
How have you written complete code without knowing for what electronics?
What kind of LEDs, what kind of motors?
Well, I know the basics. I know that I have to connect every component with a Pin on my Arduino, and I don’t really have to know more than that to start programming, but making a circuit with Leds is not really the problem. It’s the motors I found difficult.
And I use the components i got with the starter kits. It doesn’t really say what kind of leds, but the DC motor is a “Small DC motor 6/9V”
This is my code If you are curious:
#include <SPI.h> //What is used to communicate witht he WiFi chip
#include <WiFi101.h> //Wifi library fro Arduino MKR1000 and WiFi shield
int motorPin = 11;
int red =  10; //Digital pin that LED is connected to on the MKR1000
int yellow = 9;
int green = 8;
char ssid[] = "";   // your network password
//int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS; //status of wifi
WiFiServer server(80); //declare server object and spedify port, 80 is port used for internet
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(yellow, OUTPUT);
  pinMode(motorPin, OUTPUT);
  //Uncomment serial for debugging and to see details of WiFi connection
  while (!Serial) {
     // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
   Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
   Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
  WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            client.print("Value at A0 is ");
            client.print(analogRead(A0));
            client.print("
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          else {      // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r') {    // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H1")) {
          digitalWrite(red, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L1")) {
          digitalWrite(red, LOW);                // GET /L turns the LED off
        if (currentLine.endsWith("GET /H2")) {
          digitalWrite(yellow, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L2")) {
          digitalWrite(yellow, LOW);                // GET /L turns the LED off
        if (currentLine.endsWith("GET /H3")) {
          digitalWrite(green, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L3")) {
          digitalWrite(green, LOW);                // GET /L turns the LED off
        if (currentLine.endsWith("GET /DC1")) {
              analogWrite(motorPin, 100);
        if (currentLine.endsWith("GET /DC2")) {
              analogWrite(motorPin, 0);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Have you just posted your wifi password with a probably unique SSID on the internet?
If you know how to use current limiting resistors and LEDs than you should look up driving a dc motor with arduino on google. In your kit probably should be a NPN transistor suitable for a small DC motor. You are going to need a separate power source to drive the motors too. I can not be sure if you have all the stuff in your kit, there are hundreds out there. Start here: https://projectignite.autodesk.com/app/project/60/Arduino-Project-9-Motorized-Pinwheel/overview/
Thanks a lot!
