Help needed with Time based Relay ESP8266
I was trying to control a relay based on time.
What I am able to achieve is to display time on an OLED display and update it via WiFi.
Here is the code
  #include <ESP8266WiFi.h>
    #include <time.h>
    #include <SPI.h>
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #define OLED_RESET LED_BUILTIN //4
    Adafruit_SSD1306 display(OLED_RESET);
    const char* ssid = "WiFi Name";
    const char* password = "WiFi Password";
    int ledPin = 13;
    int relay=14;
    int timezone = 5.5 * 3600;
    int dst = 0;
    #if (SSD1306_LCDHEIGHT != 32)
    #error("Height incorrect, please fix Adafruit_SSD1306.h!");
    #endif
       display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
       pinMode(relay,OUTPUT);
       // Clear the buffer.
       display.clearDisplay();
       display.display();
       pinMode(ledPin,OUTPUT);
       digitalWrite(ledPin,LOW);
       display.setTextSize(1);
       display.setTextColor(WHITE);
       display.setCursor(0,0);
       display.println("Wifi connecting to ");
       display.println( ssid );
       WiFi.begin(ssid,password);
       display.println("\nConnecting");
       display.display();
       while( WiFi.status() != WL_CONNECTED ){
          display.print(".");
          display.display();
       display.display();
       display.println("Wifi Connected!");
       display.print("IP:");
       display.println(WiFi.localIP() );
       display.display();
       configTime(timezone, dst, "pool.ntp.org","time.nist.gov");
       display.println("\nWaiting for NTP...");
       while(!time(nullptr)){
          Serial.print("*");
       display.println("\nTime response....OK");
       display.display();
       display.display();
       time_t now = time(nullptr);
       struct tm* p_tm = localtime(&now);
       Serial.print(p_tm->tm_mday);
       Serial.print("/");
       Serial.print(p_tm->tm_mon + 1);
       Serial.print("/");
       Serial.print(p_tm->tm_year + 1900);
       Serial.print(" ");
       Serial.print(p_tm->tm_hour);
       Serial.print(":");
       Serial.print(p_tm->tm_min);
       Serial.print(":");
       Serial.println(p_tm->tm_sec);
       display.setTextSize(3);
       display.print(p_tm->tm_hour);
       display.print(":");
       if( p_tm->tm_min <10)
          display.print("0");
       display.print(p_tm->tm_min);
       display.setTextSize(2);
       display.setCursor(90,5);
       display.print(".");
       if( p_tm->tm_sec <10)
          display.print("0");
       display.print(p_tm->tm_sec);
       display.setCursor(0,24);
       display.print(p_tm->tm_mday);
       display.print("/");
       display.print(p_tm->tm_mon + 1);
       display.print("/");
       display.print(p_tm->tm_year + 1900);
       display.display();
       if((p_tm->tm_hour)>20)
          digitalWrite(relay,HIGH);
       if((p_tm->tm_hour)<20)
          digitalWrite(relay,LOW);
       delay(1000); // update every 1 sec
I am new to coding, Someone please update the code with the following feature.
The relay should turn on at 21H (9PM) and turn off at 7H (7AM).
I have posted the same question on stackexchange, but no help received yet.
So where are you stuck ?
This section of code
  if ((p_tm->tm_hour) > 20)
    digitalWrite(relay, HIGH);
  if ((p_tm->tm_hour) < 20)
    digitalWrite(relay, LOW);
is doing part of what you want by the look of it but the code has no test for 7am as far as I can see. Have you tried adding it ?
Use an if/else construction there, that's going to be the easiest:
if (time between 7 and 20) relay off
else relay on
