I am busy creating a prototype controller. the problem I am having is with a toggle switch that have two on positions. each on position on the toggle must send a single keyboard input. but with my current sketch when the switch is flipped in either on position it just keeps on sending the keyboard input. How can I get either on position to send just a single character/Key?
/ Keyboard - Version: Latest
#include <Keyboard.h>
int toggle1 = 6;
int toggle1State = 0;
int toggle2 = 5;
int toggle2State = 0;
pinMode(toggle1, INPUT);
pinMode(toggle2, INPUT);
Keyboard.begin();
toggle1State = digitalRead(toggle1);
toggle2State = digitalRead(toggle2);
if (toggle1State == HIGH)
Keyboard.press('r');
else{Keyboard.release('r');}
if (toggle2State == HIGH)
Keyboard.press('t');
else{Keyboard.release('t');}
You need to detect when the switch becomes on rather than when it is on.
Look at the StateChangeDetection example in the IDE
Okay so had a look at the suggested example and came up with the following. it works as I want but I would just like to know if the code is optimal and if there is a way I can improve it?
const int toggle1 = 6;
int lastToggle1State = 0;
Keyboard.begin();
if (toggle1State != lastToggle1State)
Keyboard.press('1');
else if (toggle1State == LOW)
Keyboard.release('1');
delay(50);
lastToggle1State = toggle1State;
if (toggle1State == lastToggle1State)
delay(50);
As the code posted does not compile then the answer is yes, it can be improved
It does compile and upload the sketch to the chip. I probably should have mentioned that the end goal is to use 4-6 toggle switches all using 2 inputs. Here is the complete sketch I currently have with two joysticks each with a push button, one push button and then the toggle switch.
// Keyboard - Version: Latest
#define joyLX A2 // Pin for the left joystick x-axis
#define joyLY A3 // Pin for the left joystick y-axis
int joyLB = 3; // Pin for the left joystick button
int joyLBstate = 0;
int joyLBstate1 = 0;
#define joyRX A1 // Pin for the right joystick x-axis
#define joyRY A0 // Pin for the right joystick y-axis
int joyRB = 2; // Pin for the right joystick button
int joyRBstate = 0;
int joyRBstate1 = 0;
int pushButton = 4; //// Pin for the push button
int pushButtonState = 0;
const int toggle1 = 6; // Pin for toggle switch first High position
int toggle1Counter = 0;
const int toggle2 = 5; // Pin for toggle switch second High position
int toggle2Counter = 0;
int lastToggle2State = 0;
pinMode(joyLB,INPUT);
digitalWrite(joyLB, HIGH);
pinMode(joyRB, INPUT);
digitalWrite(joyRB, HIGH);
pinMode(pushButton,INPUT);
Keyboard.begin();
int lxValue=analogRead(joyLX);
int lyValue=analogRead(joyLY);
Serial.print(lxValue);
Serial.print("\t");
Serial.println(lyValue);
joyLBstate = digitalRead(joyLB);
Serial.println(joyLBstate);
//joystick move in -y axis direction
if (lxValue>=0 && lyValue<=10)
Keyboard.press('a');
else{Keyboard.release('a');}
//joystick move in -x axis direction
if (lxValue<=0 && lyValue>=10)
Keyboard.press('s');
else{Keyboard.release('s');}
//joystick move in +x axis direction
if (lxValue>=1000 && lyValue>=100)
Keyboard.press('w');
else{Keyboard.release('w');}
//joystick move in +y axis direction
if (lxValue>=100 && lyValue>=1000)
Keyboard.press('d');
else{Keyboard.release('d');}
// if the left joy stick button is pushed
if (joyLBstate == LOW)
Serial.println("Switch = High");
Keyboard.press('e');
else{Keyboard.release('e');}
pushButtonState = digitalRead(pushButton);
if (pushButtonState == HIGH)
Keyboard.press('f');
else{Keyboard.release('f');}
// compare the buttonState to its previous state
// if the state has changed, increment the counter
// if the current state is HIGH then the button went from off to on:
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
delay(50);
if (toggle2State != lastToggle2State)
Keyboard.press('2');
else if (toggle2State == LOW)
Keyboard.release('2');
delay(50);
lastToggle2State = toggle2State;
if (toggle2State == lastToggle2State)
delay(50);
The code in reply #2 does not compile because toggle is not declared
