Help needed with WHILE-DO and FOR-NEXT loop using UNO Rev3
Hi there,
I am a new Arduino user and I'm struggeling with coding a loop using the WHILE-statement and FOR-statement.
My sketch is able to show and read 20 One-Wire temperture sensors (Maxim DS18B20) on the serial monitor with temperature readings but; I would like to replace the following part in the code by a WHILE-DO statement or FOR-NEXT statement:
  Serial.print("> UNO_R3>    * Sensor 1 temperature:  ");
  printTemperature(sensor1); // call the printTemperature function with the address of sensor1 as input
  Serial.print("> UNO_R3>    * Sensor 2 temperature:  ");
  printTemperature(sensor2); // call the printTemperature function with the address of sensor2 as input
  Serial.print("> UNO_R3>    * Sensor 3 temperature:  ");
  printTemperature(sensor3); // call the printTemperature function with the address of sensor3 as input
  Serial.print("> UNO_R3>    * Sensor 4 temperature:  ");
  printTemperature(sensor4); // call the printTemperature function with the address of sensor4 as input
Etcetera, etc.
It should be something like this:
var = 1;
while (var < 21) {
   Serial.print("> UNO_R3>   * Sensor " var " temperature: ");
   printTemperature(sensor var); // call the printTemperature function with the corresponding sensor number as input
   var ++;
   if (var == 21)  var = 1;
Remember I am a starter and any help would be highly appreciated!
Regards Rne
Please post your full current sketch so that the context can be seen
It sounds like you need to use an array of values because variable names are not known at run time so you cannot just concatenate text together to create the name of a variable
My full sketch is as follows:
 *   FILE:          Multi_DS18B20_Temperatures_OneWireBus_102
 *   AUTHOR:        RPvN
 *   VERSION:       1.04
 *   DATE:          22 September 2021 (initial version)
 *   HISTORY:       25 September 2021 Update (V1.01)
 *                  28 September 2021 Resolution settings added (V1.02)
 *                  05 October 2021   Software heardbeat monitor LED on pin 13 added (V1.03)
 *                  06 October 2021   Software upgraded to 20 DS18B20 devices on a single 1-Wire Bus (V1.04)
 *   REF.No:        061600OCT21_104
 *   PURPOSE:       This sketch sets up 1-Wire Bus communication between an Arduino Uno Rev3 and multiple DS18B20 temperature sensors.
 *                  It shows:
 *                    - Baudrate setting for the serial monitor,
 *                    - GPIO-pin used for collecting data from the 1-Wire Bus,
 *                    - Number of connected devices,
 *                    - Unique 64-bit lasered ROM codes of each connected DS18B20 device,
 *                    - Resolution setting (9, 10, 11 or 12 bits) and corresponding conversion time
 *                      prior to measuring and displaying the temperature of each device.
 *                  Temperature is shown in Kelvin (K), degrees Farenheid (°F) an degrees Centigrade (°C).
 *                  This sketch is NOT sponsored by the well known fastfood restaurant, any simularities are just by coincident ;-)
 *   Original sketch from: https://www.best-microcontroller-projects.com/ds18b20.html (Arduino Sketch 1; OneWire DS18S20, DS18B20, DS1822 Temperature Example)
 *   CONNECTIONS:   Put a 10 µF electrolytic capacitor between VDD and GND that acts as an power buffer at the start of the 1-Wire Bus.
 *                  When large numbers of devices are connected to the same 1-Wire Bus, additional capacitors are used at regular intervals (minimum of one per eight to ten devices).
 *                  A single 4K7 Bus Pull-Up resistor is necessary between VDD and DQ, which should be placed between the Arduino and first device on the Data-line of the 1-Wire Bus.
 *                  Lower the value of the Bus Pull-Up resistor to a minimum of 2K2 when using very long wires to pass more current.
 *                  Fit each device with a 100 nF decoupling capacitor, this will reduce High Frequency noise signals and prevent bad readings.
 *                  Position it as close as it can be to the corresponding ds218b20 device.
 *                  Connect a resistor of 100 to 120 Ohms to the DQ-pin of each device, before connecting it to the 1-Wire Bus DQ-line.
 *                  This will reduce reflections significally, especially when more than ten devices are connected to the same 1-Wire Bus.
 *                  Keep in mind, that large number of devices on the 1-Wire Bus, will slow down the update rate due to the conversion time of each device and displaying temperatures.
// Declare specific constants and/or variables:
int gpioPin = 2;                // Arduino GPIO-pin for connecting to 1-Wire Bus
int baudRate = 9600;            // Baud rate for serial port
int deviceCount = 0;            // Initializes/resets device counter
//  int res9 = 9;                   // 9-bits resolution (0.5 ºC)     conversion time = 93.75 ms
//  int res10 = 10;                 // 10-bits resolution (0.25 ºC)   conversion time = 187.5 ms
//  int res11 = 11;                 // 11-bits resolution (0.125 ºC)  conversion time = 375 ms
int res12 = 12;                 // 12-bits resolution (0.0625 ºC) conversion time = 750 ms
float versionSketch = 1.04;     // Keeping track of software version
// Initializes variables for temperatures in degrees Kelvin, Fahrenheid and Celsius ("KFC"-format)
float tempK;
float tempF;
float tempC;
// Hexadecimal addresses of all the DS18B20 sensors connected to the 1-Wire bus:
byte sensor1[8] = {0x28, 0x20, 0x49, 0xCB, 0x0A, 0x00, 0x00, 0x75};
byte sensor2[8] = {0x28, 0x48, 0xF6, 0xC9, 0x0A, 0x00, 0x00, 0x30};
byte sensor3[8] = {0x28, 0xBC, 0xAC, 0xCA, 0x0A, 0x00, 0x00, 0x3E};
byte sensor4[8] = {0x28, 0x62, 0x28, 0xCC, 0x0A, 0x00, 0x00, 0x34};
byte sensor5[8] = {0x28, 0x1A, 0x03, 0xCA, 0x0A, 0x00, 0x00, 0x8C};
byte sensor6[8] = {0x28, 0x9A, 0xF1, 0xCC, 0x0A, 0x00, 0x00, 0x4A};
byte sensor7[8] = {0x28, 0xFA, 0xD8, 0xCA, 0x0A, 0x00, 0x00, 0x8B};
byte sensor8[8] = {0x28, 0x8E, 0xDA, 0xCA, 0x0A, 0x00, 0x00, 0x4C};
byte sensor9[8] = {0x28, 0xC1, 0xA8, 0xCA, 0x0A, 0x00, 0x00, 0xF3};
byte sensor10[8] = {0x28, 0x59, 0x04, 0xCB, 0x0A, 0x00, 0x00, 0x7E};
byte sensor11[8] = {0x28, 0xB5, 0x85, 0xCA, 0x0A, 0x00, 0x00, 0xA3};
byte sensor12[8] = {0x28, 0x6D, 0xF8, 0xC9, 0x0A, 0x00, 0x00, 0xCF};
byte sensor13[8] = {0x28, 0xED, 0xF0, 0xC9, 0x0A, 0x00, 0x00, 0x1B};
byte sensor14[8] = {0x28, 0x03, 0xF6, 0xCC, 0x0A, 0x00, 0x00, 0x3C};
byte sensor15[8] = {0x28, 0xD3, 0xC7, 0xCC, 0x0A, 0x00, 0x00, 0xB1};
byte sensor16[8] = {0x28, 0x8B, 0x54, 0xCA, 0x0A, 0x00, 0x00, 0xCE};
byte sensor17[8] = {0x28, 0x9B, 0x22, 0xCC, 0x0A, 0x00, 0x00, 0x6D};
byte sensor18[8] = {0x28, 0xF7, 0x1E, 0xCC, 0x0A, 0x00, 0x00, 0x76};
byte sensor19[8] = {0x28, 0x0F, 0x53, 0xCA, 0x0A, 0x00, 0x00, 0xA9};
byte sensor20[8] = {0x28, 0xFF, 0x8F, 0xCC, 0x0A, 0x00, 0x00, 0xAD};
// Include the required Arduino libraries:
#include <OneWire.h>
#include <DallasTemperature.h>
// Define to which pin of the Arduino the 1-Wire bus is connected:
#define ONE_WIRE_BUS 2
// Create a new instance of the oneWire class to communicate with any OneWire device:
OneWire oneWire(ONE_WIRE_BUS);
// Pass the oneWire reference to DallasTemperature library:
DallasTemperature sensors(&oneWire);
DeviceAddress deviceAddress; // variable to store the device address
  // Start of program, setup only runs once after power-up or a reset
  // initialize digital pin 13 (LED_BUILTIN) as an output
  pinMode(LED_BUILTIN, OUTPUT);
  // turn the LED located on the Arduino board and connected to GPIO-pin 13 (LED_BUILDIN) on, by making the voltage HIGH (turning on and later off repeatedly, is used as a software heartbeat)
  digitalWrite(LED_BUILTIN, HIGH);
   // Begin serial communication at a baud rate of 9600:
   Serial.begin(baudRate);
  //Show sketch name and software version
  Serial.println("*** Multiple DS18B20's on 1-Wire Bus ***");
  // Show software version of the sketch
  Serial.print("***      Software version: ");
  Serial.print(versionSketch);
  Serial.println("      ***");
  Serial.println("****************************************");
  //Show Arduino board being used
  Serial.println("> UNO_R3> Arduino reports READY!");
  // Show Baud rate
  Serial.print("> UNO_R3> Baud rate for serial port set to: ");
  Serial.print(baudRate);
  Serial.println(" Baud");
  // Show GPIO-pin used for connecting to 1-Wire Bus
  Serial.print("> UNO_R3> 1-Wire Bus connected to GPIO-pin: ");
  Serial.println(gpioPin);
  // Start up the library:
  sensors.begin();
  Serial.print("UNO_R3> Checking for devices on 1-Wire Bus ");
  for (int i = 0;  i < 2; i++) {
    Serial.print(". ");
  delay(750);
  Serial.println(".!");
  Serial.print("> UNO_R3>   * Found ");
  deviceCount = sensors.getDeviceCount();
  Serial.print(deviceCount);
  Serial.println(" device(s)");
  // Identifying and showing devices on the 1-Wire Bus:
  Serial.print("UNO_R3> Identifying and showing connected devices by their unique 64-bit lasered ROM code ");
    Serial.print(". ");
  delay(750);
  for (int i = 0;  i < deviceCount;  i++) {
    Serial.print("> UNO_R3>   * Sensor ");
    Serial.print(i + 1);
    Serial.print(" (Hexadecimals): ");
    sensors.getAddress(deviceAddress, i);
    printAddress(deviceAddress);
    // Set resolution of a specific device to; 9, 10, 11 or 12 bits
    sensors.setResolution(deviceAddress, res12);
    Serial.print(i+1);
    Serial.print(" set to ");
    Serial.print(res12);
    Serial.println("-bits resolution (0.0625 ºC), conversion time = 750 ms");
  // turn the LED off the Arduino board connected to pin 13 (LED_BUILDIN) on by making the voltage LOW
  digitalWrite(LED_BUILTIN, LOW);
  Serial.println("UNO_R3> Measuring and displaying temperature(s) from connected device(s):");
  // Send the command for all devices on the bus to perform a temperature conversion:
  sensors.requestTemperatures();
  // turn the LED on the Arduino board connected to pin 13 (LED_BUILDIN) on by making the voltage HIGH
  // Show mesurments after a short delay and start again
  delay(750);
  Serial.print("> UNO_R3>    * Sensor 5 temperature:  ");
  printTemperature(sensor5); // call the printTemperature function with the address of sensor5 as input
  Serial.print("> UNO_R3>    * Sensor 6 temperature:  ");
  printTemperature(sensor6); // call the printTemperature function with the address of sensor6 as input
  Serial.print("> UNO_R3>    * Sensor 7 temperature:  ");
  printTemperature(sensor7); // call the printTemperature function with the address of sensor7 as input
  Serial.print("> UNO_R3>    * Sensor 8 temperature:  ");
  printTemperature(sensor8); // call the printTemperature function with the address of sensor8 as input
  Serial.print("> UNO_R3>    * Sensor 9 temperature:  ");
  printTemperature(sensor9); // call the printTemperature function with the address of sensor9 as input
  Serial.print("> UNO_R3>    * Sensor 10 temperature: ");
  printTemperature(sensor10); // call the printTemperature function with the address of sensor10 as input
  Serial.print("> UNO_R3>    * Sensor 11 temperature: ");
  printTemperature(sensor11); // call the printTemperature function with the address of sensor11 as input
  Serial.print("> UNO_R3>    * Sensor 12 temperature: ");
  printTemperature(sensor12); // call the printTemperature function with the address of sensor12 as input
  Serial.print("> UNO_R3>    * Sensor 13 temperature: ");
  printTemperature(sensor13); // call the printTemperature function with the address of sensor13 as input
  Serial.print("> UNO_R3>    * Sensor 14 temperature: ");
  printTemperature(sensor14); // call the printTemperature function with the address of sensor14 as input
  Serial.print("> UNO_R3>    * Sensor 15 temperature: ");
  printTemperature(sensor15); // call the printTemperature function with the address of sensor15 as input
  Serial.print("> UNO_R3>    * Sensor 16 temperature: ");
  printTemperature(sensor16); // call the printTemperature function with the address of sensor16 as input
  Serial.print("> UNO_R3>    * Sensor 17 temperature: ");
  printTemperature(sensor17); // call the printTemperature function with the address of sensor17 as input
  Serial.print("> UNO_R3>    * Sensor 18 temperature: ");
  printTemperature(sensor18); // call the printTemperature function with the address of sensor18 as input
  Serial.print("> UNO_R3>    * Sensor 19 temperature: ");
  printTemperature(sensor19); // call the printTemperature function with the address of sensor19 as input
  Serial.print("> UNO_R3>    * Sensor 20 temperature: ");
  printTemperature(sensor20); // call the printTemperature function with the address of sensor20 as input
  Serial.println("> UNO_R3>    Starting measurements again . . .");
void printAddress(DeviceAddress deviceAddress) {
  for (uint8_t i = 0; i < 8; i++) {
    Serial.print("0x");
    if (deviceAddress[i] < 0x10) {
      Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
    if (i < 7) {
      Serial.print(", ");
void printTemperature(DeviceAddress address) {
  // Fetch the temperature in degrees Celsius for device address:
  float tempC = sensors.getTempC(address);
  // Fetch the temperature in degrees Fahrenheit for device address:
  float tempF = sensors.getTempF(address);
  // Calculate the temperature in Kelvin from fetched tempC
  float tempK = tempC + 273;
  // Print the temperature in Kelvin
  Serial.print(tempK);
  Serial.print(" K  |  ");
  // Print the temperature in Fahrenheit
  Serial.print(tempF);
  Serial.print(" \xC2\xB0"); // shows degree symbol
  Serial.print("F  |  ");
  // Print the temperature in Celsius
  Serial.print(tempC);
  Serial.println("C");
First you need to do as @UKHeliBob suggested and use an array for all your temperature readings. If you don't know about arrays read this: array - Arduino Reference
Then you need to use a for loop to print them, something like this (not tested):
float temperatureReadings[21] {}; // Put your readings in here, 0 to 20
uint8_t i;
for (i = 0; i < 21; ++i) {
Serial.print ("Sensor ");
Serial.print (i);
Serial.print (" Temperature = ");
Serial.println (temperatureReadings[i]);
This:
var = 1;
while (var < 21) {
   var ++;
Will never exit the while loop, I leave you to work out why.
[Edit: I see from your reply #4, which you made while I was typing mine, you do know how to use an array. Should be easy then]
Many thanks, I will do some more studying and experimenting with the array-topic you have suggested.
The never ending loop in the WHILE-statement is because; it always will be smaler than 21 when I use the IF-statement the way I did.
It was in a time, long, long ago, that I've been doing basic coding in Turbo Pascal.
Regards Rne
Start with an array of addresses:
byte Sensors[][8] =
  {0x28, 0x20, 0x49, 0xCB, 0x0A, 0x00, 0x00, 0x75},
  {0x28, 0x48, 0xF6, 0xC9, 0x0A, 0x00, 0x00, 0x30},
  {0x28, 0xBC, 0xAC, 0xCA, 0x0A, 0x00, 0x00, 0x3E},
  {0x28, 0x62, 0x28, 0xCC, 0x0A, 0x00, 0x00, 0x34},
  {0x28, 0x1A, 0x03, 0xCA, 0x0A, 0x00, 0x00, 0x8C},
  {0x28, 0x9A, 0xF1, 0xCC, 0x0A, 0x00, 0x00, 0x4A},
  {0x28, 0xFA, 0xD8, 0xCA, 0x0A, 0x00, 0x00, 0x8B},
  {0x28, 0x8E, 0xDA, 0xCA, 0x0A, 0x00, 0x00, 0x4C},
  {0x28, 0xC1, 0xA8, 0xCA, 0x0A, 0x00, 0x00, 0xF3},
  {0x28, 0x59, 0x04, 0xCB, 0x0A, 0x00, 0x00, 0x7E},
  {0x28, 0xB5, 0x85, 0xCA, 0x0A, 0x00, 0x00, 0xA3},
  {0x28, 0x6D, 0xF8, 0xC9, 0x0A, 0x00, 0x00, 0xCF},
  {0x28, 0xED, 0xF0, 0xC9, 0x0A, 0x00, 0x00, 0x1B},
  {0x28, 0x03, 0xF6, 0xCC, 0x0A, 0x00, 0x00, 0x3C},
  {0x28, 0xD3, 0xC7, 0xCC, 0x0A, 0x00, 0x00, 0xB1},
  {0x28, 0x8B, 0x54, 0xCA, 0x0A, 0x00, 0x00, 0xCE},
  {0x28, 0x9B, 0x22, 0xCC, 0x0A, 0x00, 0x00, 0x6D},
  {0x28, 0xF7, 0x1E, 0xCC, 0x0A, 0x00, 0x00, 0x76},
  {0x28, 0x0F, 0x53, 0xCA, 0x0A, 0x00, 0x00, 0xA9},
const byte SensorCount = sizeof Sensors / sizeof Sensors[0];
Then use a 'for' loop:
  for (byte i=0; i < SensorCount; i++)
    Serial.print(i+1);
    Serial.print(" temperature:  ");
    printTemperature(Sensors[i]); // call the printTemperature function with the address of sensor1 as input
Thanks, I will do some experimenting with this code.
With regards Rne
