Help Needed
Hi, Im new to arduino and on my first project. Im trying to get codes from a 433mhz remote so I can control remote power sockets from a 4 by 4 keypad. The control has on and off buttons for each adapter instead of just 1 button for on and off. Iv got it working using 2 buttons for on and off but I wanted to use just one button to turn each socket on and off. Has anyone got any ideas how I could do this please. Here is some sample code I am using:
#include <Keypad.h>
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
const byte ROWS = 4;
const byte COLS = 4;
// Define the Keymap
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3, 2 };
// Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(10);
mySwitch.setPulseLength(190);
char key = kpd.getKey();
if(key) // Check for a valid key.
switch (key)
case '1':
mySwitch.send("000101010101110100000011"); \button on code
case '2':
mySwitch.send("000101010101110100001100"); \button off code
default:
Serial.println(key);
Thanks
Use a variable to remember the current state:
byte state = 0;
and modify your case statement as follows:
  switch (key)
  case '1':
    if (state == 0) {
      \\button on code
    else {
      \\button off code
    state = !state; //Swap the state: if it is 0, make it 1, if it is 1, make it 0
Hi, Thanks for the reply. It worked perfectly. Now im trying to add the second button but it doesn't seem to wont to work. Button 2 is working fine but button 1 turns both button 1 and 2 on and off at the same time. Do you know what might be wrong. Here is the code.
#include <Keypad.h>
byte state1 = 0;
byte state2 = 0;
switch (key)
case '1':
if (state1 == 0) {
mySwitch.send("000101010111010100000011");
else {
mySwitch.send("000101010111010100001100");
case '2':
if (state2 == 0) {
else {
state1 = !state1; //Swap the state: if it is 0, make it 1, if it is 1, make it 0
state2 = !state2; //Swap the state: if it is 0, make it 1, if it is 1, make it 0
Thanks
You have the state swapping in the wrong place.
Try this:
    switch (key)
      case '1':
        if (state1 == 0) {
      else {
      case '2':
      if (state2 == 0) {
      else {
Thank you. Its all working perfectly now. :slight_smile:
