help needed
Hi people
I have a problem and I dont know how to solve it.
my code is this…
      if  (average > 0)
        dir = HIGH;
      else if (average < 0)
        dir = LOW;
      int i;
      digitalWrite(dirpin, dir);     // Set the direction.
      delay(100);
      for (i = 0; i<average; i++)       // Iterate for 4000 microsteps.
        digitalWrite(steppin, LOW);  // This LOW to HIGH change is what creates the
        digitalWrite(steppin, HIGH); // "Rising Edge" so the easydriver knows to when to step.
        delayMicroseconds(200);      // This delay time is close to top speed for this
but it only goes in 1 direction.
this is because of this line…
it does not work if (average) is a -#
how do i make (average) always be a +# ??
thanks :slight_smile:
abs http://arduino.cc/en/Reference/Abs
You could use the abs() function to get the absolute value of average or just test it yourself as shown below.
Cheers
      int absavg;            //ADDED
      if  (average > 0)
        dir = HIGH;
       absavg = average;    //ADDED
        dir = LOW;
        absavg = -average;      //ADDED
      int i;
      delay(100);
      for (i = 0; i<absavg; i++)      //CHANGED  // Iterate for 4000 microsteps.
how can this work ?
for (i = 0; i<absaverage; i++)
if (absaverage) was not declared ??
cheers
abs is a function (or a macro) Or you coulld define "absavg"
abs(x)
Description
Computes the absolute value of a number.
Parameters
x: the number
Returns
x: if x is greater than or equal to 0.
-x: if x is less than 0.
This is what i dont want to happen …
i need -x to be x even if its <0 :slight_smile:
I’s a function; it doesn’t change the value of its argument, unless you make it.
for (i = 0; i<abs(average); i++)
so now my code looks like this…
      int dir;
      if  (average > 0)
        dir = HIGH;
        dir = LOW;
      int i;
      delay(100);
      for (i = 0; i<abs(average); i++)      //CHANGED  .
and i still get the -#
what am i doing wrong??? :slight_smile:
Where do you get the -ve value?
     total= total - readings[index];
     readings[index] = step_value;
    total= total + readings[index];
    index = index + 1;
    if (index >= numReadings)
    index = 0;
    // calculate the average:
    average = total / numReadings;
my average range is from +30 to -30
I’m not following you - from your original post, you need average to be +ve or -ve to allow you to set the direction.
if “x < 0”, then “-x” is a +ve number.
If you never need it to be -ve, simply set “avg = abs (avg);”
Thanks Groove
you helped lots :) :) :)
how can this work ?
Code:
cheers
Yeah - I noticed my typo and fixed it almost immediately. Wonder why you still got the older version that much later?
cheers.
