Help needed!!
Hi everyone! I am probably the stupidest person you will come across on this forum. I am very unsure on how to use Arduinos or how to use programming to it’s potential. i have a few problems.
  1. How to I get the Pots to work when you turn them?
  2. How do you change the analogue reference voltage to Internal?
  3. I want to display the attenuation of the potentiometers in dB. When the pots are at max, the attenuation should be 0dB and when at min it should be a large negative number. Underneatht the values of the pot on the display, calculate and display the dB attenuation.
Thank you so much for your help, much appreciated :slight_smile:
Here is the program.
#define lin_pot 5
#define log_pot 4
#include <LiquidCrystal.h>
#define rs 8
#define rw 9
#define d4 10
#define d5 11
#define d6 12
#define d7 13
#define lcd_enable 17
// define variables
LiquidCrystal lcd(rs, rw, lcd_enable, d4, d5, d6, d7);
int analog_val_lin, analog_val_log;
lcd.begin(20,4);
lcd.home();
lcd.print(“Lin pot =”);
lcd.setCursor(0,2);
lcd.print(“Log pot =”);
lcd.setCursor(10,0);
lcd.print(analog_val_lin);
lcd.print(" “);
lcd.print(” dB “);
lcd.setCursor(10,2);
lcd.print(analog_val_log);
lcd.print(” ");
You have to read a value with analogRead before you display it
what do you mean?
You're just printing the values for the pots, but you haven't assigned any values to them. Have a look at the language reference for analogRead.
