HELP, NRF24L01 SERVO AND POTENTIOMETER
ok so ive boiled it down to the fact that something is wrong with the servo (receiver).
It keeps randomly spinning when the pot isnt moving, the tx is working perfectly according to teh serial output, but the rx serial isnt working properly, its slow and for some reason it keeps moving all around into one position.
Tx output:
sent data 169
sent data 111
sent data 75
sent data 76
sent data 76
Rx output(the serial rx is sorta stuck as this):
incoming 28
incoming 28
incoming 28
incoming 28
incoming 0
incoming 0
incoming 28
incoming 28
incoming 178
incoming 0
incoming 28
incoming 28
I do not know what else to try. The code works for me so there is something different about your setup.
One thing that is mentioned in the tutorial and that I found to be true is that the radios do not reset when that Arduino is reset. Sometimes it helps if, after you upload new code, power down the Arduino and then power back up. Cycling the power to the rf24 will get it to reset.
