Help on building an array ,
// BOARD
// Arduino Mega 2560 Rev3
byte DisplayData1[5];
void setup(){
DisplayData1[0] = 0;
DisplayData1[1] = 25;
DisplayData1[2] = 14;
DisplayData1[3] = 255;
DisplayData1[4] = 254;
//byte DisplayData1[5] = { 0, 25, 14, 255, 254 }; Won’t compile
/* I will use this to store byte data to a big array to
send to a graficdisplay , but it will not give any data from the
array other than 0 to the portK out , the other way above is
not a way to go for me , it’s to much data to handel
for (int j= 0; j < 5; j++) {
/* Example
(DDRK = 11111111)
Here i will catch byte data from DisplayData[j]
and send it to a port set för 1 byte output
(PORTK = DisplayData1[j]
Have you tried this?
byte DisplayData1[] = { 0, 25, 14, 255, 254 };
etc
THANKS it worked ! , didn't find the answer in ref. Many thanks !
Because the reference section is a supplement to your C/C++ book, where the answer is. You DO have one, don't you?
