i know the power needs to be seperate but can i use audio input, button read and pot in same run of cat6
without crosstalk or bleedover???
the cat6 has the plastic separator between the pairs but is that enough to create a barrier? i would like to use the cat6 since it is all i have now. if there is any recommendations on cabling, please provide.
i basically have 4 pin headers for connectors from main board to secondary board with above items on it.
header #1 - 4 leds sharing ground with #2
header #2 - pot, dimmer, 5v and gnd
header #3 - envelope signal, 5v and gnd
As you will be using low voltage and I assume low current (indicator LEDS?) there is no need to separate power and other circuits except for the audio that may require screened cable.
I second what weedpharma said. Separate out the audio and use your the cat 6 (or even cat 5) for the rest. Assuming the length is not too great. You're not going all the way across a college campus with this are you?
it is for my car lighting system i posted about earlier in general discussion
basically the main board is in a box next to battery under hood and the cables will be run through firewall to dash area. +/- 6 feet
in the post earlier i had everything on separate wires sitting next to each other testing it. now i need to run the cables and get set inside the car.
i am asking cause the sound detector i built works great on bench with full system but when connecting at the car it tends to act like it is picking up loud noise most of the time even though the ambient noise is rather quiet. i would have to reset board a few times to get working properly.
another confusion issue:
what type of shielded cable? how many conductors?
i happen to have a cable that has a red and black wrapped in foil and drain wire outside of that.
will that work and if so, what would the connections be??? will following work???
red = 5v
black = audio signal
drain = gnd
i'm used to using the drain as a secondary or isolated gnd, if needed. will the 5v and audio next to each other cause interference?
You can use the cable you have. I would keep that cable for microphone audio only. Connect the microphone to the two wires and earth the shield at one end only to avoid earth loops.
