Try this:
#include <DogLcd.h>
// initialize the library with the numbers of the interface pins
DogLcd lcd(9, 10, 11, 12);
#include <IRremote.h>
int receiver = 8; // Conectar IR Receiver na porta digital 8
IRrecv irrecv(receiver); // Criar objeto 'irrecv'
decode_results results;
lcd.begin(DOG_LCD_M163,0x28);
lcd.clear();
delay(100);
// Serial.begin(9600); // for serial monitor output
irrecv.enableIRIn(); // Start the receiver
IR_code();
void IR_code()
if (irrecv.decode(&results)) // have we received an IR signal?
//lcd.print(results.value, DEC); // Imprimir na porta serial o valor do controle
switch(results.value)
case 59:
lcd.print(" Menu ");
break;
case 2107:
break;
case 32:
lcd.print(" up ");
break;
case 2080:
lcd.print(" up ");
break;
case 33:
lcd.print(" down ");
break;
case 2081:
break;
case 16:
lcd.print(" right ");
break;
case 2064:
break;
case 17:
lcd.print(" left ");
break;
case 2065:
lcd.print("left ");
break;
case 37:
lcd.print(" OK/Enter ");
break;
case 2085:
lcd.print("OK/Enter ");
break;
case 55:
lcd.print(" Exit ");
break;
case 2103:
break;
case 2049:
lcd.print(" 1 ");
break;
case 1:
lcd.print(" 1 ");
break;
case 2:
lcd.print(" 2 ");
break;
case 2050:
lcd.print(" 2 ");
break;
case 3:
lcd.print(" 3 ");
break;
case 2051:
lcd.print(" 3 ");
break;
case 4:
lcd.print(" 4 ");
break;
case 2052:
lcd.print(" 4 ");
break;
case 5:
lcd.print(" 5 ");
break;
case 2053:
lcd.print(" 5 ");
break;
case 6:
lcd.print(" 6 ");
break;
case 2054:
lcd.print(" 6 ");
break;
case 7:
lcd.print(" 7 ");
break;
case 2055:
lcd.print(" 7 ");
break;
case 8:
lcd.print(" 8 ");
break;
case 2056:
lcd.print(" 8 ");
break;
case 9:
lcd.print(" 9 ");
break;
case 2057:
lcd.print(" 9 ");
break;
case 0:
lcd.print(" zero ");
break;
case 2048:
break;
default:
lcd.print(" other button ");
irrecv.resume(); // receive the next value
} // Your loop can do other things while waiting for an IR command
