I know I'm doing something really stupid right now, but where and how do I place that in the code? It keeps saying: expected constructor, destructor, or conversion type before '.' token
And it says "rgb[0] was not declared in this scope"
We're working blind here - can you post your code and tell us what it is you want to do?
If you don't have something like "byte rgb [3];" declared somewhere in scope, your code won't compile.
Place the print code after you have set the values so for example you could put it at the end of the void RGBCommonLED::updateLED(){ definition.
OR
If you want to be able to print from anywhere then move the definition of the rgb[] array so that it is global. That is move it to outside a function to the start of the sketch. Then you can put the print statements anywhere you like,
P.S. Forgot to include a semicolon at the end of all the print lines, now corrected.
Thanks it's working great but how do I change this part:
randomSeed(analogRead(0));
testRGB();
void testRGB(){
led1.setRGB(255,0,0);
led1.updateLED();
led1.setRGB(0,255,0);
led1.updateLED();
led1.setRGB(0,0,255);
led1.updateLED();
delay(2000);
return;
led1.setRandomHue();
led1.setSat(255);
led1.setVal(255);
led1.updateLED();
delay(3000);
led1.setRandomColor();
led1.updateLED();
return;
so that there is no "test" and it only show one color, not changing the color?
Take everything in the loop() function and put it in the setup() function.
The loop() function will be empty but you still need it.
Also there is no need to have a return statement at the end of a function.
testRGB();
void testRGB(){
led1.updateLED();
led1.updateLED();
led1.updateLED();
delay(2000);
return;
led1.setSat(255);
led1.setVal(255);
led1.updateLED();
delay(3000);
led1.updateLED();
It says " error: expected constructor, destructor, or type conversion before '.' token" right here:
You can't just paste code between function definitions like that.
led1.updateLED();
(untested)
yours worked, only every color it showed was white, or at least all the values were at zero the whole time. I got this:
led1.setSat(255);
led1.setVal(255);
led1.updateLED();
delay(3000);
led1.updateLED();
but how do I make it so that it doesn't flash, wait for a second or more, and then show the color? I just want it to show the color
I'm not sure I understood what you want but here's my attempt to help you:
Seems like you just need to remove the Delay.
Have fun
It wasn't mine, it was yours, with the code in proper functions.
As I said, untested - I don't have your hardware, I was just working on the code as you posted it.
it doesn't matter whose it was I was just referring to what you posted
Are these two the same?:
led1.setSat(255);
led1.setVal(255);
led1.updateLED();
led1.updateLED();
And I know it's probably inevitable, but why are there occaisionally 3 of the same colors in a row?
int buttonstate;
int val;
int val2;
int switchpin = 5;
int redPin = 3;
int bluePin = 5;
int greenPin = 6;
int redIn = 2;
int greenIn = 3;
int blueIn = 4;
int redVal;
int greenVal;
int blueVal;
#ifndef RGBCommonLED_H
#define RGBCommonLED_H
#include "WProgram.h"
class RGBCommonLED {
public:
RGBCommonLED(int rpin, int gpin, int bpin);
~RGBCommonLED();
void setRGB(byte r, byte g, byte b);
void setHSV(byte h, byte s, byte v);
void setColor(unsigned long v);
void setHue(byte level);
void setSat(byte level);
void setVal(byte level);
void adjHue(int level);
void adjSat(int level);
void adjVal(int level);
void setRandomColor();
void setRandomHue();
void setRandomSat();
void setRandomVal();
void setHSVLevel(int section, byte level);
void adjHSVLevel(int section, int level);
void setRandomHSVLevel(int section);
void updateLED();
void HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
unsigned int *oR, unsigned int *oG, unsigned int *oB );
void RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
unsigned int *oH, unsigned int *oS, unsigned int *oV );
void updateHSVFromRGB();
int pins[3];
int rgb[3];
int hsv[3];
private:
boolean hsvSet;
void setRGBFromHSV();
void setHSVFromRGB();
#endif
RGBCommonLED::RGBCommonLED(int rpin, int gpin, int bpin){
pins[0] = rpin;
pins[1] = gpin;
pins[2] = bpin;
hsvSet = false;
RGBCommonLED::~RGBCommonLED(){
void RGBCommonLED::setColor(unsigned long v)
this->setRGB((v & 255),((v >> 8) & 255),(v >> 16) & 255);
void RGBCommonLED::setRGB(byte r, byte g, byte b){
rgb[0] = r;
rgb[1] = g;
rgb[2] = b;
hsvSet = false;
void RGBCommonLED::setHSV(byte h, byte s, byte v){
hsv[0] = h;
hsv[1] = s;
hsv[2] = v;
this->setRGBFromHSV();
hsvSet = true;
void RGBCommonLED::setHSVLevel(int section, byte level){
updateHSVFromRGB();
hsv[section] = level;
void RGBCommonLED::setHue(byte level){
this->setHSVLevel(0,level);
void RGBCommonLED::setSat(byte level){
this->setHSVLevel(1,level);
void RGBCommonLED::setVal(byte level){
this->setHSVLevel(2,level);
void RGBCommonLED::adjHSVLevel(int section, int level){
updateHSVFromRGB();
int th = hsv[section] + level;
if( th < 0 ){
th = 255 + th;
else if( th > 255 ) {
th = 255 - th;
th = constrain(th,0,255);
hsv[section] = th;
void RGBCommonLED::adjHue(int level){
this->adjHSVLevel(0,level);
void RGBCommonLED::adjSat(int level){
this->adjHSVLevel(1,level);
void RGBCommonLED::adjVal(int level){
this->adjHSVLevel(2,level);
void RGBCommonLED::RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
double vals[3];
unsigned char maxc=0, minc=0;
double hue, sat, val;
vals[0]=inRed;
vals[1]=inGreen;
vals[2]=inBlue;
//red is set as maximum and minimum
if(vals[1]>vals[maxc]) maxc=1;
if(vals[2]>vals[maxc]) maxc=2;
if(vals[1]<vals[minc]) minc=1;
if(vals[2]<vals[minc]) minc=2;
val = vals[maxc];
if(vals[maxc]==0)
sat = hue = 0;
sat=255*(1-(vals[minc]/vals[maxc]));
hue = 60 * ((maxc*2) + (vals[(maxc+1)%3] - vals[(maxc+2)%3])/(vals[maxc] - vals[minc]));
if(hue < 0) hue += 360; //corrector for hues in -60 to 0 range
*oH = hue; //map(hue,0,360,0,255);
*oS = sat;
*oV = val;
void RGBCommonLED::HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
if( inSaturation == 0 )
// achromatic (grey)
*oR = *oG = *oB = inValue;
unsigned int scaledHue = (inHue * 6);
unsigned int sector = scaledHue >> 8; // sector 0 to 5 around the color wheel
unsigned int offsetInSector = scaledHue - (sector << 8); // position within the sector
unsigned int p = (inValue * ( 255 - inSaturation )) >> 8;
unsigned int q = (inValue * ( 255 - ((inSaturation * offsetInSector) >> 8) )) >> 8;
unsigned int t = (inValue * ( 255 - ((inSaturation * ( 255 - offsetInSector )) >> 8) )) >> 8;
switch( sector ) {
case 0:
*oR = inValue;
*oG = t;
*oB = p;
case 1:
*oR = q;
*oG = inValue;
*oB = p;
case 2:
*oR = p;
*oG = inValue;
*oB = t;
case 3:
*oR = p;
*oG = q;
*oB = inValue;
case 4:
*oR = t;
*oG = p;
*oB = inValue;
default: // case 5:
*oR = inValue;
*oG = p;
*oB = q;
void RGBCommonLED::setRandomColor(){
this->setColor((unsigned long)random(0x01000000));
void RGBCommonLED::setRandomHue(){
this->setRandomHSVLevel(0);
void RGBCommonLED::setRandomSat(){
this->setRandomHSVLevel(1);
void RGBCommonLED::setRandomVal(){
this->setRandomHSVLevel(2);
void RGBCommonLED::setRandomHSVLevel(int section){
this->setHSVLevel(section, (unsigned int)random(0x0100));
void RGBCommonLED::updateHSVFromRGB(){
this->setHSVFromRGB();
hsvSet = true;
[glow]void RGBCommonLED::updateLED(){
analogWrite(this->pins[0], rgb[0]);
analogWrite(this->pins[1], rgb[1]);
analogWrite(this->pins[2], rgb[2]);
Serial.print(" R - ");
Serial.print(rgb[0] , DEC);
Serial.print(" G - ");
Serial.print(rgb[1] , DEC);
Serial.print(" B - ");
Serial.println(rgb[2] , DEC);
}[/glow]
void RGBCommonLED::setRGBFromHSV(){
unsigned int h = hsv[0];
unsigned int s = hsv[1];
unsigned int v = hsv[2];
unsigned int r = 0;
unsigned int g = 0;
unsigned int b = 0;
HSVToRGB(h,s,v,&r,&g,&b);
this->setRGB(r,g,b);
void RGBCommonLED::setHSVFromRGB(){
unsigned int r = rgb[0];
unsigned int g = rgb[1];
unsigned int b = rgb[2];
unsigned int h;
unsigned int s;
unsigned int v;
this->RGBToHSV(r,g,b,&h,&s,&v);
hsv[0] = map(h,0,360,0,255);
hsv[1] = s;
hsv[2] = v;
hsvSet = true;
RGBCommonLED led1(10,11,9);
pinMode(switchpin, INPUT);
led1.setSat(255);
led1.setVal(255);
led1.updateLED();
buttonstate = digitalRead(switchpin);
redVal = analogRead(redIn);
greenVal = analogRead(greenIn);
blueVal = analogRead(blueIn);
redVal = map(redVal, 0, 1023, 0, 255);
greenVal = map(greenVal, 0, 1023, 0, 255);
blueVal = map(blueVal, 0, 1023, 0, 255);
analogWrite(redPin, redVal);
analogWrite(greenPin, greenVal);
analogWrite(bluePin, blueVal);
val = digitalRead(switchpin);
delay(10);
val2 = digitalRead(switchpin);
if(val == val2) {
if(val != buttonstate) {
if(val == LOW) {
[glow] if(rgb[0] >= redPin) {[/glow]
Serial.print("red is less");
Do I need to make the first highlighted part global so that it can be used for the second part that is highlighted? Because it says rgb[0] was not defined in scope for the second highlighted part. If so, how do you make it global?
