help on RC Missile Launcher
hey guys. I have been working on an RC Plane Missile Launcher. My plane uses 3 channels, and my TX /RX is 4 channels (I’m pretty cheap like that) so pretty much I have been making an arming system so that if I move my channel one way for 3 seconds, then the other way for 3 seconds out goes my rocket. Here is the code:
#include <Servo.h>
#define RC 3
int RC_new = 0;
int Right = 0;
int Left = 0;
int held = 0;
  pinMode(RC, INPUT);
  Serial.begin(57600);
  Serial.println("Done with setup");
void SerialCheck()
  Serial.print("Right: ");
  Serial.println(Right);
RC_new = ((pulseIn (RC, HIGH, 100000))/10)-100; //read RC value.. store it fresh
//check for a transition
if ((RC_new > 90))
    held = held + 1;
    delay(0001); //it isn't exactily 1/1000th of a second, it's a bit more with program lag.
    //if button is held down over 200 (about 3 secs)
    if ((held < 200));
      Right =1;
 Serial.print(Right);
 Serial.print(" RC Value: ");
 Serial.print(RC_new);
 Serial.print(" Held Time: ");
 Serial.println(held);
Now my issue is that right when I plug in my LiPo, the channel jumps, but that only makes my held time go up for a second or so.
Here is the Serial Log:
Right: 0 RC Value: -100 Held Time: 0
Right: 1 RC Value: 421 Held Time: 1
Right: 1 RC Value: 388 Held Time: 2
Right: 1 RC Value: 386 Held Time: 3
Right: 1 RC Value: 5439 Held Time: 4
Right: 1 RC Value: 5439 Held Time: 5
Right: 1 RC Value: 5438 Held Time: 6
Right: 1 RC Value: 5438 Held Time: 7
Right: 1 RC Value: 5438 Held Time: 8
Now as you can see, the Right = 1; line should only happen once held is over 200… what is happening guys!
NOTE: This is only for the right script, my left script will come after I can get this half running.
    if ((held < 200));
      Right =1;
You might want to look at that line again…
I honestly cannot thank you enough. Is there any particular reason the compiler didn't catch that?
Yes, as it is no syntax error but a semantic or logic error. Programmers are responsible for the latter. Compilers can only catch the first.
