HELP on simultanious Serial.Print and MIDI out on a Mega2560
Hi All, I'm looking for some help to get the Serial.Print (for debugging) and MIDI out on a Mega2560 to work at the same time. It is my understanding that the MEGA has 4 UARTs, so shouldn't this be possible?
Thanks, Barilium8
Yes, it's totally possible. If you fix your code it will work.
Can you be a bit more specific? :-)
Not until you are. It's hard for me to see the mistake in your code right now. If you give me your address I could pop by and have a look if it's not too far. Or you could post it. That would probably be easier. Don't forget code tags.
