Help on Timer code
timer0_overflow_count=0;
heixin:
i'm tyring to reset timer and start timer
Why?
For calculating pulses.
So you're pulling out your hair trying to reset millis when all you have to do is...
unsigned long Start;
unsigned long Stop;
unsigned long Delta;
void setup( void )
void loop( void )
  // Put code here to wait for pulse start
  Start = millis();
  // Put code here to wait for pulse stop
  Stop = millis();
  Delta = Stop - Start;
  // Put code here to use Delta (pulse width in milliseconds)
You may get help resetting millis but it will not be from me. Especially given the fact that a simple solution is so readily available.
heixin:
Thanks.!but i'm calculating in bits not millis.
I don't understand that. Bits is not a time interval, nor is millis(). millis() is a function.
What was wrong with Coding Badly's solution?
i'm finding a way to reset and start timer.
Look, if you want to cook a roast turkey for 2 hours, do you reset the clock on the wall back to midnight? Or do you make a note of the time you started cooking, and then notice when 2 hours have passed?
