I an using a NodeMCU 0.9 (ESP-12 Module) to measure three DS18B20. The script reads the sensors every second or two for 1-2 min. then averages the reading and put the averages in a string that is sent out in a email ~hour or so. The script then it does a ESP.restart to start over. This was the only way I could get the script to send an email more than once.
I would take the emails, copy the text strings, copy and paste them into excel for processing. The text string would go into excel as one string and I had to parse and put into 4 columns. Three temperature columns and one time column.
I tried include various combinations of \r and \n so that each line of data would be copy into excel as a separate row so I could delimit them using commas and a tab.
To test out what I needed I used a send one email script and change the \r & \n combinations. I figured out what I needed do but I can't understand what rules they follow.
Can someone explain why I can't add "\r" , "/n" , "\r\n" to a string in a Serial.print to get a CR. But I can if they are added as string variable?
Second part of the question: It seems that "/n" , "\r\n" can be added to a string (as a string variable) if using Serial.print but not "\r"? But if in the string I am sending out in an email I have to use "\r", "\r\n" because "/n" will not work?
I have included full email once script I am using and the results from everything that worked and did not work. I have to believe I am not the only one to have run into this using "\r" , "/n" , "\r\n". Sorry for the long drawn out story but you can't search for anything with a " or ' using Google. It just ignores the " and ' characters in the search.
//THESE ARE THE RESULTS OF VARIOUS CHANGES IN THE CODE LINES OF INTEREST
CR1="\r\n";
Temp1 = "This appears on one line" + CR1 + "And this appears on a new line";
CR1="\r\n And this appears on a new line";
Temp1 = "This appears on one line" + CR1;
Temp1 = "This appears on one line" + "\r\n And this appears on a new line";
G:\Arduino\Email_Single_Send_Latest\Email_Single_Send_Latest.ino: In function 'void setup()':
G:\Arduino\Email_Single_Send_Latest\Email_Single_Send_Latest.ino:133:36: error: invalid operands of types 'const char [25]' and 'const char [34]' to binary 'operator+'
133 | else
| const char [25] const char [34]
Multiple libraries were found for "SD.h"
Used: C:\Users\Tom5810\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD
Not used: C:\Users\Tom5810\AppData\Local\Arduino15\libraries\SD
exit status 1
Compilation error: invalid operands of types 'const char [25]' and 'const char [34]' to binary 'operator+'
Temp1 = "This appears on one line" + "\r\n" + "And this appears on a new line";
G:\Arduino\Email_Single_Send_Latest\Email_Single_Send_Latest.ino:133:36: error: invalid operands of types 'const char [25]' and 'const char [3]' to binary 'operator+'
133 | else
| const char [25] const char [3]
exit status 1
Compilation error: invalid operands of types 'const char [25]' and 'const char [3]' to binary 'operator+'
CR1="\r\n";
Serial.println("test>>>>>>>>>>>>>>>> " + Temp1);
delay(100);
Serial.println(Temp1);
delay(100);
SERIAL PRINTS THIS:
test>>>>>>>>>>>>>>>> This appears on one line
CR1="\n";
delay(100);
delay(100);
SERIAL PRINTS THIS:
CR1="\r";
delay(100);
delay(100);
SERIAL PRINTS THIS:
test>>>>>>>>>>>>>>>> This appears on one lineAnd this appears on a new line
HOWEVER IF I COPY (CTRL-C / CTRL-V) THE ABOVE TEXT FROM THE ARDUINO SERIAL MONITOR IT PUTS THIS NOTEPAD DOC A CR IS INSERTED AS SHOWN BELOW:
//WITH THIS CODE:
CR1="\n";
//Send raw text message
String textMsg = "Hello World! - Sent from ESP board " + Temp1;
//THE RECEIVED EMAIL LOOKS LIKE THIS:
//Hello World! - Sent from ESP board This appears on one line And this appears on a new line
//WITH THIS CODE:
CR1="\r"; // or if I use CR1="\r\n";
//And this appears on a new line
THIS IS THE FULL SCRIPT >>>>>>>>>>>>>>>>>>>>>>>>
SENDS ONE SINGLE EMAIL MODIFIED EXAMPLE BY ME
Rui Santos
Complete project details at:
- ESP32: https://RandomNerdTutorials.com/esp32-send-email-smtp-server-arduino-ide/
- ESP8266: https://RandomNerdTutorials.com/esp8266-nodemcu-send-email-smtp-server-arduino/
https://raw.githubusercontent.com/RuiSantosdotme/Random-Nerd-Tutorials/master/Projects/ESP/ESP_Email_Simple.ino
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
Example adapted from: https://github.com/mobizt/ESP-Mail-Client
#include <Arduino.h>
#if defined(ESP32)
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#endif
#include <ESP_Mail_Client.h>
#define WIFI_SSID "XXXXXXXXX"
#define WIFI_PASSWORD "XXXXXXXXXX"
/** The smtp host name e.g. smtp.gmail.com for GMail or smtp.office365.com for Outlook or smtp.mail.yahoo.com */
#define SMTP_HOST "server146.web-hosting.com"
#define SMTP_PORT 465
#define AUTHOR_PASSWORD "XXXXXXXXXXXXXXXXXXXXX"
/* Recipient's email*/
#define RECIPIENT_EMAIL "XXX@XXXXXXXXXX.com"
/* Declare the global used SMTPSession object for SMTP transport */
SMTPSession smtp;
/* Callback function to get the Email sending status */
String CR1 = "";
String Temp1 = "";
void smtpCallback(SMTP_Status status);
void setup(){
CR1="\r" ;
delay(100);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
delay(100);
Serial.print("Connecting to Wi-Fi");
delay(100);
while (WiFi.status() != WL_CONNECTED){
Serial.print(".>");
delay(300);
delay(100);
Serial.print("Connected with IP: ");
delay(100);
delay(100);
delay(100);
delay(100);
/* Set the network reconnection option */
MailClient.networkReconnect(true);
/** Enable the debug via Serial port
* 0 for no debugging
* 1 for basic level debugging
* Debug port can be changed via ESP_MAIL_DEFAULT_DEBUG_PORT in ESP_Mail_FS.h
smtp.debug(1);
/* Set the callback function to get the sending results */
smtp.callback(smtpCallback);
/* Declare the Session_Config for user defined session credentials */
Session_Config config;
/* Set the session config */
config.server.host_name = SMTP_HOST;
config.server.port = SMTP_PORT;
config.login.email = AUTHOR_EMAIL;
config.login.password = AUTHOR_PASSWORD;
config.login.user_domain = "";
Set the NTP config time
For times east of the Prime Meridian use 0-12
For times west of the Prime Meridian add 12 to the offset.
Ex. American/Denver GMT would be -6. 6 + 12 = 18
See https://en.wikipedia.org/wiki/Time_zone for a list of the GMT/UTC timezone offsets
config.time.ntp_server = F("pool.ntp.org,time.nist.gov");
config.time.gmt_offset = 3;
config.time.day_light_offset = 0;
/* Declare the message class */
SMTP_Message message;
/* Set the message headers */
message.sender.name = F("ESP");
message.sender.email = AUTHOR_EMAIL;
message.subject = F("ESP Test Email ");
message.addRecipient(F("Tom"), RECIPIENT_EMAIL);
/*Send HTML message*/
/*String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Hello World!</h1><p>- Sent from ESP board</p></div>";
message.html.content = htmlMsg.c_str();
message.text.charSet = "us-ascii";
message.html.transfer_encoding = Content_Transfer_Encoding::enc_7bit;*/
CR1="\n";
message.text.content = textMsg.c_str();
message.text.transfer_encoding = Content_Transfer_Encoding::enc_7bit;
message.priority = esp_mail_smtp_priority::esp_mail_smtp_priority_low;
message.response.notify = esp_mail_smtp_notify_success | esp_mail_smtp_notify_failure | esp_mail_smtp_notify_delay;
/* Connect to the server */
if (!smtp.connect(&config)){
ESP_MAIL_PRINTF("Connection error, Status Code: %d, Error Code: %d, Reason: %s", smtp.statusCode(), smtp.errorCode(), smtp.errorReason().c_str());
return;
if (!smtp.isLoggedIn()){
Serial.println("\nNot yet logged in.");
else{
if (smtp.isAuthenticated())
Serial.println("\nSuccessfully logged in.");
Serial.println("\nConnected with no Auth.");
/* Start sending Email and close the session */
if (!MailClient.sendMail(&smtp, &message))
ESP_MAIL_PRINTF("Error, Status Code: %d, Error Code: %d, Reason: %s", smtp.statusCode(), smtp.errorCode(), smtp.errorReason().c_str());
void loop(){
void smtpCallback(SMTP_Status status){
/* Print the current status */
Serial.println(status.info());
/* Print the sending result */
if (status.success()){
// ESP_MAIL_PRINTF used in the examples is for format printing via debug Serial port
// that works for all supported Arduino platform SDKs e.g. AVR, SAMD, ESP32 and ESP8266.
// In ESP8266 and ESP32, you can use Serial.printf directly.
Serial.println("----------------");
ESP_MAIL_PRINTF("Message sent success: %d\n", status.completedCount());
ESP_MAIL_PRINTF("Message sent failed: %d\n", status.failedCount());
Serial.println("----------------\n");
for (size_t i = 0; i < smtp.sendingResult.size(); i++)
/* Get the result item */
SMTP_Result result = smtp.sendingResult.getItem(i);
// In case, ESP32, ESP8266 and SAMD device, the timestamp get from result.timestamp should be valid if
// your device time was synched with NTP server.
// Other devices may show invalid timestamp as the device time was not set i.e. it will show Jan 1, 1970.
// You can call smtp.setSystemTime(xxx) to set device time manually. Where xxx is timestamp (seconds since Jan 1, 1970)
ESP_MAIL_PRINTF("Message No: %d\n", i + 1);
ESP_MAIL_PRINTF("Status: %s\n", result.completed ? "success" : "failed");
ESP_MAIL_PRINTF("Date/Time: %s\n", MailClient.Time.getDateTimeString(result.timestamp, "%B %d, %Y %H:%M:%S").c_str());
ESP_MAIL_PRINTF("Recipient: %s\n", result.recipients.c_str());
ESP_MAIL_PRINTF("Subject: %s\n", result.subject.c_str());
// You need to clear sending result as the memory usage will grow up.
smtp.sendingResult.clear();
