Help on understanding data structure usage
I am writing a code to transmit a packet using wifi module NRF24L01. Not very much familiar with the structures. Kindly help me out to correct the error below.
Highlighted line : radio.write( &controldata, sizeof(controldata) );
exit status 1
expected primary-expression before ‘,’ token
My code is as below,
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CNS, CE
const byte address[6] = "00001";
struct controldata {
  int Xa;
  int Ya;
  int sw;
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  int potValueX = analogRead(A0);
  int angleValueX = map(potValueX, 0, 1023, 0, 255);
  int potValueY = analogRead(A1);
  int angleValueY = map(potValueY, 0, 1023, 0, 255);
  controldata variable = {angleValueX,angleValueY,0 };
  delay(300);
Thanks.
  radio.write( &variable, sizeof(controldata) );
  radio.write( (byte*) &variable, sizeof(controldata) );
cattledog:
Casting the pointer to byte* is completely unnecessary. It's not even the type that RF24::write accepts, so it'll need to implicitly casted again anyway.
Thanks guys. Can you also advice how to print structure variables using Serial.println.
With the dot operator.
Thanks a lot.
I often use a print() member function of the structure,
remember that structures are mere classes with default public attributes.
Whandall:
The Arduino core provides an abstract class called Printable that you can inherit from and implement the virtual function virtual size_t printTo(Print& p) const. Then, for any class that inherits from Print (like Serial or LCD), they get the size_t print(const Printable&); function that will call your class's printTo function.
