I'm new to using E-paper display and so I wanted to ask if it was possible to know if
this display was compatible with an esp32 and if it was possible to use it as an image displayer (even one at a time is good).
The official webstore: https://www.waveshare.com/4.2inch-e-paper-module-b.htm
I'm using this ESP32-CH340 from AZ-Delivery.
Yesterday I tried with uncommenting line 280 in examples/GxEPD2_Example/GxEPD2_display_selection.h:
// GxEPD2_3C<GxEPD2_420c_Z21, GxEPD2_420c_Z21::HEIGHT> display(GxEPD2_420c_Z21(/*CS=5*/ SS, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // GDEQ042Z21 400x300, UC8276
(old style)
And also tried uncommenting line 93 in examples/GxEPD2_Example/GxEPD2_display_selection_new_style.h
//#define GxEPD2_DRIVER_CLASS GxEPD2_420c_Z21 // GDEQ042Z21 400x300, UC8276, (hidden)
The wiring i'm using is described at line 74 in examples/GxEPD2_Example/GxEPD2_wiring_examples.h:
// BUSY -> 4, RST -> 0, DC -> 2, CS -> SS(5), CLK -> SCK(18), DIN -> MOSI(23), GND -> GND, 3.3V -> 3.3V // for use with Board: "ESP32 Dev Module":
I tried this the other day and worked, but after some testing it started displaying noise, I've already checked if it's a wiring issue and I'm pretty confident that it's not the case.
I'm now buying another display to check if it's a hardware-related issue, but for now some help would be really appreciated.
Thanks to anyone answering to this post.
Best Regards.
P.S
I'm using Adafruit_GFX not the GFX class provided by GxEPD2.
I've tried using the "new style" and "old style" for initializing the display, neither work after my second attempt, I've tried using the old style alone, and i can at least "talk" to the display, using the new style alone doesn't even initialize the display object for me.
