help on voice controlled robot using arduino
So i want to work on a voice controlled robot using arduino. but the ones i see online its only ( left right front and back) that the robot can do i want to know if it is possible to make a robot that does to a specific location , also the materials and code that i will need to implement it .
And have you already built a working voicontroled robot or are you looking for someone to do the research + work for you for free?
yeah i have a working project but its the regular left front right left own. i actually just wanted to know if someone has done anything different from that.
Perhaps you could explain what "does to a specific location" means.
If it should be "goes" how do you expect to give it a location to go to using voice control? What sort of location? How will it know where it is now and where the specified location is? Indoors or our? If it's indoors you can't use GPS.
Steve
slipstick:
Steve
specific location i mean from a room to another ( its indoor by the way)
Use the forum Google search function in the upper right of this page to search for the key words of your project. You will probably find many similar previous project discussions and code to get you started.
zoomkat:
thanks
