Help on which part I need to connect arduino to an existing RC car
Hi guys,
I'd like to connect arduino to an existing rc car and control it with my phone/bluetooth. My goal is to build a rc self driving car (I've already made this project with the arduino car set, now I'd like to do it again with a better car). So what I also need is a camera connected to my arduino and send all the image captured to my phone via bluetooth.
I searched for a tutorial online but they looks really complicated and I don't understand what I really need.
This is a list of what I understood I need:
  • Mini USB Board ATmega328 5V 16MHz CH340 ATmega328P Micro Controller
  • L293D Motor Driver Shield (4 motor)
  • Arduino bluetooth adapter
Do I need something else? Do I need Arduino Uno or the ATmega328 can replace it? Can I use the servo that is already present in my rc car or should I buy a custom servo in order to send arduino commands to it? Also,do you have a good tutorial on how to connect all the cables to the arduino board?
Thank you in advance!
The processor on the Uno is the ATmega328.
Hard to say since we can't see the servo, but if it is a standard RC hobby servo you should be able to control it with the ATmega328. Just make sure to power it with a supply that can provide adequate current.
If you are using batteries to power the car, the ancient technology L293 is a poor choice of motor driver. Actually no matter how it is powered the L293 is a poor choice. The L293 will drop 2 to over 4 volts of your motor power supply as waste heat. Very inefficient. Pololu (among others) has a good line of modern MOSFET output drivers that are very efficient.
Thank you for your answer! The rc car is a classic 1:16 scale car that you can buy on amazon/supermarket, so as you said I'll probably need another servo.
About the Pololu motors, do I need a single or dual motor?
