Help optimizing a function
I haven't read everything here but I spotted this line in your code
if(millis() == thermocouple.timeout)
That is not the correct way to use millis() for 2 reasons.
First millis() does not return every successive value so it might never actually equal the timeout value - you should use >=
Second, the code will fail gloriously when millis() rolls over to 0.
Your test should be "millis() - prevMillis >= interval"
You need to post the entire code rather than little pieces that have no context. If it's a large program perhaps you can write a short sketch that illustrates the problem.
...R
