Hi all, I'm unable to compile my code due to a lack of SRAM on my Uno - my global variables use 117% of dynamic memory, and the IDE says that I'm 358 bytes over.
I'm a beginner when it comes to different data types and optimizing memory usage, so any immediate changes I can make to my code would be appreciated.
#define LIN_OUT 1 // use the log output function
#define FFT_N 256 // set to 256 point fft
#define DC_OFFSET 511
#include <FFT.h> //FFT library
#include <FastLED.h> //FastLED library
#define LED_DT 6 //LED data pin
#define COLOR_ORDER GRB //WS2812b specific
#define LED_TYPE WS2812B
#define NUM_LEDS 288 //Number of LEDs in project
#define COL_HEIGHT 9 //height of column
int adc_val;
struct CRGB leds[NUM_LEDS];
Serial.begin(9600); // use the serial port
delay(1000); //soft startup to ease flow of
LEDS.addLeds<LED_TYPE, LED_DT, COLOR_ORDER>(leds, NUM_LEDS);
TIMSK0 = 0; // turn off timer0 for lower jitter - delay() and millis() killed
ADCSRA = 0xe5; // set the adc to free running mode
ADMUX = 0x40; // use adc0
DIDR0 = 0x01; // turn off the digital input for adc0
getFFT();
fftDisplay();
FastLED.show();
void getSound() {
while (1) { // reduces jitter
cli(); // UDRE interrupt slows this way down on arduino1.0
for (int i = 0 ; i < FFT_N * 2 ; i += 2) { // save 256 samples
while (!(ADCSRA & 0x10)); // wait for adc to be ready
ADCSRA = 0xf5; // restart adc
byte m = ADCL; // fetch adc data
byte j = ADCH;
int k = (j << 8) | m; // form into an int
k -= DC_OFFSET;
adc_val = k<<6;
fft_input[i] = adc_val; // put real data into even bins
fft_input[i + 1] = 0; // set odd bins to 0
sei(); // turn interrupts back on
void getFFT() {
// window data, then reorder, then run, then take output
getSound(); //High speed sound sampling
fft_window(); // window the data for better frequency response
fft_reorder(); // reorder the data before doing the fft
fft_run(); // process the data in the fft
fft_mag_lin(); // take the output of the fft
void fftDisplay() {
int i, j, colHeight, startIndex;
for(i = 1; i < 33; i+=2) //traverse odd index bins of FFT output starting from 2nd bin (index 1), 'i' also represents col #
colHeight = (unsigned char)map(fft_lin_out[i], 0, 255, 0, 9); //map FFT output from 0-255 (value of unsigned char) to 0-9
startIndex = 9 * (i-1); //starting LED index of ith column
for(j = startIndex; j < (startIndex + COL_HEIGHT); j++) //traverse LEDs in ith column (for odd # columns)
if(j < (startIndex + colHeight)) //turn on colHeight specified # of LEDs in ith column
leds[j] = CRGB::White;
else //turn off all other LEDs in ith column
leds[j] = CRGB::Black;
for(i = 2; i < 33; i += 2) //traverse even index bins of FFT output starting from 3rd bin (index 2), 'i' also represents col #
startIndex = 9 * i - 1;
for(j = startIndex; j > (startIndex - COL_HEIGHT); j--)
if(j > (startIndex - colHeight))
