Hello,
I recently purchased ELEGOO's Smart Robot Car kit 3.0 for a line following project. The whole kit can be seen here ELEGOO UNO R3 Project Smart Robot Car Kit V 3.0 Plus – ELEGOO Official but in summary, the kit comes with a 3 channel IR sensor, L298N module, 4 DC Motors, a sensor shield and a MCU similar to Arduino UNO. The kit comes with a simple line following algorithm but I studied the control principle of PID and wanted to implement that instead.
The car follows a straight line just fine but as soon as it arrives near a bend (or if there is an error produced), the car starts oscillating left and right of the track without actually moving forward. It keeps doing that.
My guess was that the Kp is probably too large and thats why it was oscillating like that but I have tried reducing it and even tried adding in Kd to dampen the oscillations but the best I have gotten to is that the swing of the oscillations is reduced but the car still does not move forward and keeps oscillating left and right. P.S. I have only changed Kp and Kd values so far because I didnt think Ki is that necessary for line following so currently I'm only using a PD controller.
The code I used is as shown below.
//Line Tracking IO define
#define LT_R !digitalRead(10)
#define LT_M !digitalRead(4)
#define LT_L !digitalRead(2)
//motors
#define ENA 5 // controls left velocity
#define ENB 6 // controls right velocity
#define IN1 7 // left motor going forward
#define IN2 8 // left motor going backward
#define IN3 9 // right motor going backward
#define IN4 11 // right motor going forward
// logical (not actual) velocity defined to be as [MIN_SPEED, MAX_SPEED]
// actual velocity used in motors is [0, MAX_SPEED]
// motors support [0, 255] range but for PID we don't want 255 max speed
#define MAX_SPEED 150
#define MIN_SPEED -150
#define INITIAL_SPEED 100
#define LOGS_ON true //used for printing to serial monitor to help with tuning
int currentSpeedRight;
int currentSpeedLeft;
float previousError;
float integral;
int previousLineTrackerPos;
// Kd > Kp > Ki because derivative < error < integral
float kd = 130;
float kp = 20;
float ki = 0;
setupLineTracker();
setupMotors();
initVariables();
void setupLineTracker() {
pinMode(LT_R,INPUT);
pinMode(LT_M,INPUT);
pinMode(LT_L,INPUT);
void setupMotors() {
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
pinMode(IN3,OUTPUT);
pinMode(IN4,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(ENB,OUTPUT);
void initVariables() {
integral = 0;
previousError = 0;
currentSpeedRight = INITIAL_SPEED;
currentSpeedLeft = INITIAL_SPEED;
float pos = getLineTrackerPosition();
float pid = calculatePID(pos, 0);
calculateSpeed(pid);
moveMotors(currentSpeedLeft, currentSpeedRight);
int getLineTrackerPosition() {
int leftReading = LT_L;
int centerReading = LT_M;
int rightReading = LT_R;
if (leftReading == LOW && centerReading == HIGH && rightReading == LOW) {
previousLineTrackerPos = 0;
return 0;
} else if (leftReading == HIGH && centerReading == HIGH && rightReading == LOW) {
previousLineTrackerPos = -1;
return -1;
} else if (leftReading == HIGH && centerReading == LOW && rightReading == LOW) {
previousLineTrackerPos = -2;
return -2;
} else if (leftReading == LOW && centerReading == HIGH && rightReading == HIGH) {
previousLineTrackerPos = 1;
return 1;
} else if (leftReading == LOW && centerReading == LOW && rightReading == HIGH) {
previousLineTrackerPos = 2;
return 2;
return previousLineTrackerPos;
float calculatePID(float pos, float setValue) {
float error = pos - setValue;
float derivative = error - previousError;
integral += error;
previousError = error;
if (error == 0 && derivative == 0) {
//means output signal of PID converged to target signal
//resets integral to zero and other control variables
initVariables();
float pid = (error * kp) + (integral * ki) + (derivative * kd);
if (LOGS_ON) {
//Serial.println(error);
//Serial.println(integral);
char toPrint[43] = "";
char value[10] = "";
//error value to char array
dtostrf(error, 10, 2, value);
strcat(toPrint, value);
strcat(toPrint, "|");
dtostrf(integral, 10, 2, value);
dtostrf(derivative, 10, 2, value);
dtostrf(pid, 10, 2, value);
Serial.println(toPrint);
return pid;
void calculateSpeed(float delta) {
int deltaInt = round(delta);
//if car is at right (delta < 0), we need to turn left
//increase right speed, decrease left speed
//or if car is at left (delta > 0), we need to turn right
//increase left speed, decrease right speed
currentSpeedRight -= deltaInt;
currentSpeedLeft += deltaInt;
currentSpeedRight = constrain(currentSpeedRight, MIN_SPEED, MAX_SPEED);
currentSpeedLeft = constrain(currentSpeedLeft, MIN_SPEED, MAX_SPEED);
void moveMotors(int leftSpeed, int rightSpeed) {
int in1Signal, in2Signal, in3Signal, in4Signal;
if (leftSpeed >= 0) {
//left motors turning forwards
in1Signal = HIGH;
in2Signal = LOW;
//left motors turning backwards
in1Signal = LOW;
in2Signal = HIGH;
if (rightSpeed >= 0) {
//right motors turning forwards
in3Signal = LOW;
in4Signal = HIGH;
//right motors turning backwards
in3Signal = HIGH;
in4Signal = LOW;
leftSpeed = abs(leftSpeed);
rightSpeed = abs(rightSpeed);
analogWrite(ENA, leftSpeed);
analogWrite(ENB, rightSpeed);
digitalWrite(IN1, in1Signal);
digitalWrite(IN2, in2Signal);
digitalWrite(IN3, in3Signal);
digitalWrite(IN4, in4Signal);
I thought the problem was with tuning but now I'm not sure if its the tuning or if there's a flaw in the algorithm?
I also attached a text file of the serial monitor output in case that helps. The values are printed in the form Time->Error l Integral l Derivative l PID value
Any help would be greatly appreciated!
pid_serial_output.txt (21.3 KB)
