Anyone please i need your help because yesterday I was building my project using the Arduino Mega ADK with Arduino GSM Shield mounted in it. My plan was to use an adaptor as it power source instead of the USB.
THE SCENARIO WAS:
After I had plug in the adaptor, the board got overheated and quickly unpluged it. I know it got overheated because it smells like burning electronics and I knew somethings goes wrong. When I came to investigate if it does still works, I tested my ADK
by plugging it in my computer, unfortunately my computer was unable to detect the ADK despite the its power is on.My GSM also doesn't work, I tested it by mounting it in my Arduino UNO and had uploaded the Arduino GSM program built-in in the Arduino IDE.
Before the bad event, I checked the web about the specification of the ADK and it says recommended(7-12V) and the limits are at (6-20v). You may check on this site.
http://arduino.cc/en/Main/ArduinoBoardMegaADK
Being aware with the voltage input and having the limited resources, I used the adaptor of my Creative SBS A300 Speaker which has the following specifications.
INPUT AC 100 - 240 V 50 / 60 HZ
OUT PUT 11.5V AC 1600 mA
You may check this for further information.
Given the information, I would like to know where is my fault so it may not happen again but I do believe that I did follow the requirements in operating the microcontrollers.
Please give me information what had happen, the fault, if their is a way to fix it, warranty or anything. Please consider my current location, I lived at Philippines. Thank you very much for giving time for reading this. I am looking forward for your comments and suggestions. I had attached an image of it .Ouch! cannot help my self seeing it unoperational.;(
