help please? how do i read variable on SD card and implement it in a program
I am lost on how to achieve obtaining a variable on the SD card and using it in a program.
This bit of code here is just me attempting to read the variable that is already on the SD card.
#include <SD.h>
#define programpin 2
const int chipSelect = 4;
File dataFile;
char filename4[] = "opsFile.csv";
char varchar;
pinMode(programpin, OUTPUT);
 Serial.begin(9600);                 // baud rate for computer serial communication
while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  pinMode(chipSelect, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
 File dataFile = SD.open(filename4);
  if(dataFile)
    while (dataFile.available())
    Serial.print("Data File Read: ");
    Serial.write(dataFile.read());
    Serial.println("");
    varchar = dataFile.read();
    Serial.print("Var Char: ");
    Serial.println(varchar);
    dataFile.close();
    Serial.print("atoi varchar to var: ");
    int var = atoi(varchar);
    Serial.print(var);
Any help would be greatly appreciated.
What do you have in the file?
What happens when you run that program?
You can't store variables on the SD card. You can store VALUES on the SD card, and the value can be the one stored in a variable.
    Serial.println("");
Read one character/byte from the file, and print it. Read and store the next character/byte read from the file, and print the stored value.
That does NOT pass the sniff test.
