Hi all,
I am having trouble with my Ether Ten from Freetronics. (built in ethernet without the shield)
using Arduino 1.0, developing on a mac
I have a Windows XP based executable that is a HTTP server, and have used this for many years collecting data from things like barcode readers.
I am attempting to take some analogue reading (maybe temerature) and send it to this server listening on 192.168.3.42
To do this I have modified the example HTTP Client code, sending the ip address of the Arduino sending data and some other value I have called “seed” here.
To make it simple there are no sensors attached, I am sending millis() - If I can get that to work then the sensor will be a snap.
THE TEST
Taking a fixed string, I send it to the server and it is accepted, as in the various fields parse out nicely - GREAT - server returns text and the serial port on the Arduino shows it.
client.println(“GET /?request=PING,from=D33,IP=123.234.444.555,seed=3 HTTP/1.1”); this yields on HTTP server
query field value
from D33
IP 123.234.444.555
seed 3
MY PROBLEM
if I cut the outgoing string into 2 pieces or more this line of code stops working
ie HttpString = “GET /?request=PING,from=D33,IP=123.234.444.555,seed=3”;
HttpString += " HTTP/1.1 " ;
client.println( HttpString );
On the server this results in varying parts of this being split onto one or many query entries with most of it missing as it has not been parsed properly. Although the serial println appears perfectly.
QUESTION
I have not used C in over fifteen years, am I not using the string properly ?
It looks ot me like I am taking a fixed string, cutting it in half and sending both halves v-s one single transmission.
I attach the code below
Thanks in advance
#include <SPI.h>
#include <Ethernet.h>
EthernetClient client;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; byte x=0;
IPAddress IPserver(192,168,3,42); // A4200
IPAddress myIP(0,0,0,0);
String HttpString="";
unsigned long time;
do {
Serial.println("Connecting ");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet");
} else { x=1;
Serial.println(" ethernet card init."); // no point in carrying on, so do nothing forevermore:
delay(1000); // give the Ethernet shield a second to initialize:
// if (Ethernet.begin(mac) == 0) { for (byte x=1;x>0;){ Serial.println("Failed to configure Ethernet using DHCP");} } // no point in carrying on, so do nothing forevermore:
myIP = Ethernet.localIP();
} while (x==0);
Serial.print("- - Connected to server @ ");
Serial.println(" 192,168,3,42");
Serial.print("My IP address: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) { // print the value of each byte of the IP address:
Serial.print( myIP[thisByte]) ;
Serial.print( ".");
Serial.println( "..." ); // top of loop
if (client.connect(IPserver, 80))
client.flush();
Serial.println(". . ."); // server connected
HttpString = "GET /?request=PING,from=D33,IP=123.234.444.555,seed=";
HttpString += String(millis(),DEC);
HttpString += " HTTP/1.1 \r\n" ;
Serial.println( HttpString );
//---{ This does not work }---//
//---{ This works evertime }---//
// client.println("GET /?request=PING,from=D33,IP=123.234.444.555,seed=3 HTTP/1.1");
time = millis() + 10000;
while (client.connected() && !client.available() && time>millis() ) {} // Wait for it....
while (client.available()) { // if there are incoming bytes available from the server, read them and print them:
char c = client.read();
Serial.print(c); // serial mon shows server text OK
Serial.println("- - No server found, timeout...");
delay(5000);
client.stop();
while (client.status() != 0) {delay(10);}
delay(2000); // delays to stop network flooding.
