Help please: Switching from Uno to Mega 2560 Display stops working,
so a little background I'm a novice with this so hopefully this is something easy to fix, I'm trying to change from using an uno to using a mega 2560 but when I move the wires across the display stops working.
I’m running:
an arduino uno connected to a
2.08" 256x64 Monochrome Graphic OLED Display Module - SPI
Pins:
13: SCL;
11: SDA;
10: CS;
9: DC;
8: RES
When I try running this program (I'm using an example I know works just in case):
#include<Arduino.h>
#include<U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include<SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include<Wire.h>
#endif
//for my display
U8G2_SH1122_256X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);       // Enable U8G2_16BIT in u8g2.h
// Copy the contents of your .xbm file below
#define ironman_width 44
#define ironman_height 64
static const unsigned char ironman_bits[] PROGMEM = {
 0x00, 0x00, 0xfc, 0x03, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x3f, 0x00, 0x00,
 0x00, 0xf8, 0xff, 0xff, 0x01, 0x00, 0x00, 0x86, 0xff, 0x1f, 0x06, 0x00,
 0x80, 0x81, 0xff, 0x1f, 0x18, 0x00, 0xc0, 0x80, 0xff, 0x1f, 0x30, 0x00,
 0x20, 0x80, 0xff, 0x1f, 0xc0, 0x00, 0x10, 0x00, 0xff, 0x0f, 0x80, 0x01,
 0x08, 0x00, 0xff, 0x0f, 0x00, 0x01, 0x08, 0x00, 0xff, 0x0f, 0x00, 0x02,
 0x08, 0x00, 0xff, 0x0f, 0x00, 0x02, 0x08, 0x00, 0xfe, 0x07, 0x00, 0x02,
 0x08, 0x00, 0xfe, 0x07, 0x00, 0x02, 0x08, 0x00, 0xfe, 0x07, 0x00, 0x02,
 0x08, 0x00, 0x00, 0x00, 0x00, 0x06, 0x08, 0x00, 0x00, 0x00, 0x00, 0x06,
 0x08, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x06,
 0x0c, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x06,
 0x06, 0x00, 0x00, 0x00, 0x00, 0x06, 0x06, 0x00, 0x00, 0x00, 0x00, 0x06,
 0x06, 0x00, 0x00, 0x00, 0x00, 0x0e, 0xc6, 0x07, 0x00, 0x00, 0x7c, 0x0e,
 0xe6, 0xff, 0xff, 0xff, 0xff, 0x0e, 0xe6, 0xff, 0x03, 0xf8, 0xff, 0x0c,
 0x02, 0x3f, 0x00, 0x80, 0x1f, 0x0c, 0x02, 0x00, 0x00, 0x00, 0x00, 0x0c,
 0x03, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x03, 0x00, 0x00, 0x00, 0x00, 0x0c,
 0x03, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x07, 0x00, 0x00, 0x00, 0x00, 0x06,
 0x07, 0x00, 0x00, 0x00, 0x00, 0x06, 0x16, 0x00, 0x00, 0x00, 0x00, 0x06,
 0x2e, 0x00, 0x00, 0x00, 0x80, 0x07, 0x6e, 0x00, 0x00, 0x00, 0x40, 0x07,
 0x6e, 0x00, 0x00, 0x00, 0x60, 0x07, 0xde, 0x00, 0x00, 0x00, 0xb0, 0x07,
 0xde, 0x00, 0x00, 0x00, 0xb0, 0x07, 0x9c, 0x01, 0x00, 0x00, 0xd8, 0x03,
 0xbc, 0x01, 0x00, 0x00, 0xf8, 0x03, 0x3c, 0x01, 0x00, 0x00, 0xe8, 0x03,
 0x7c, 0x03, 0x00, 0x00, 0xf4, 0x03, 0xfc, 0x02, 0x00, 0x00, 0xf4, 0x03,
 0xfc, 0xc2, 0xff, 0x1f, 0xfa, 0x03, 0xf8, 0x25, 0xff, 0x27, 0xfa, 0x01,
 0xf8, 0x38, 0x00, 0x60, 0xf9, 0x01, 0xf8, 0x10, 0x00, 0xc0, 0xf8, 0x01,
 0xf0, 0x00, 0x00, 0x00, 0xf8, 0x01, 0xf0, 0x00, 0x00, 0x00, 0xf8, 0x01,
 0xf0, 0x00, 0xf8, 0x00, 0xf8, 0x00, 0xe0, 0xc1, 0xff, 0x0f, 0xf8, 0x00,
 0xc0, 0xe3, 0xff, 0x1f, 0x7c, 0x00, 0x80, 0xff, 0xff, 0x7f, 0x3e, 0x00,
 0x00, 0xff, 0xff, 0x7f, 0x0f, 0x00, 0x00, 0xf6, 0x00, 0xfe, 0x07, 0x00,
 0x00, 0x3c, 0x00, 0xb0, 0x01, 0x00, 0x00, 0x08, 0x00, 0x40, 0x00, 0x00 };
void draw(void) {
 // graphic commands to redraw the complete screen should be placed here
 u8g2.drawXBMP( 42, 0, ironman_width, ironman_height, ironman_bits);
void setup(void) {
 u8g2.begin();
void loop(void) {
 // picture loop
 u8g2.firstPage();
 do {
     draw();
    } while( u8g2.nextPage() );
 // rebuild the picture after some delay
I upload the code to the Uno and the display works.
I swap the wires over to the Mega, the upload works (no errors encountered)
the display stays blank.
I'm not sure what I've done wrong
hopefully someone can help me out here.
Could maybe take a look at this link here ..... (click here)
