Hi, I am new to Arduino and have a problem that I am unsure how to fix.
I am building a fall detection circuit to detect a human falling. I have created the circuit as shown in the image attached and compiled the code attached. I am looking for the LED to come on (over port 11) when a fall occurs. However, when I run the code the LED appears always on and there is no change when a fall is simulated. Please can anyone help?
katiejayne:
The way you have your LED wired an output of HIGH is on. You have initialized the output to HIGH and it remains HIGH until a fall is detected in which you set it to LOW for 20ms and then back ON. That is a very short amount of time.
if (fall==true){ //in event of a fall detection
Serial.println("FALL DETECTED");
digitalWrite(11, LOW);
delay(20);
digitalWrite(11, HIGH);
fall=false;
// exit(1);
You need to reverse your outputs and leave the LED on longer.
hammy:
Have a read of the how to use the forum and post you code correctly . A brief explanation of how your project is supposed to work is helpful .
BTW - how will you test this and prove it works ?
Thank you, I did read but didn’t realise how much explaining I should do.
Essentially the project is a human fall detection, it’s looking to measure a significant change in acceleration and direction that is then unchanged for a period of time. As if someone has fallen and can’t get up.
I will be testing by literally simulating a fall. I.e standing and falling onto a soft mat.
How is best to post the code? Embedded in the text?
ToddL1962:
Please read the post at the start of any forum , entitled "How to use this Forum".
OR http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
