Help Please ... Uno + ENC28J60 + WAMP
Hi guys,
I have been trying for weeks to find a solution to this but after all the examples, tutorials, code snippets, etc... I just cannot get this to send the data to the server.... I am at the moment trying to get it to work with the ethercard library but I will go with whatever library will do what I need to do which is just basically send a GET request to the php page and return anything coming back but I have tried everything even the example webclient does not work, I know the ENC module works as I had been using it as a small webserver testing it
Here is the code:
// This demo does web requests to a fixed IP address, using a fixed gateway.
// 2010-11-27 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
#define REQUEST_RATE 5000 // milliseconds
// ethernet interface mac address
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
// ethernet interface ip address
static byte myip[] = { 192,168,0,203 };
// gateway ip address
static byte gwip[] = { 192,168,0,1 };
// remote website ip address and port
static byte hisip[] = { 192.168.0.242 };
// remote website name
char website[] PROGMEM = "PC2";
byte Ethernet::buffer[300];   // a very small tcp/ip buffer is enough here
static long timer;
// called when the client request is complete
static void my_result_cb (byte status, word off, word len) {
  Serial.print("<<< reply ");
  Serial.print(millis() - timer);
  Serial.println(" ms");
  Serial.println((const char*) Ethernet::buffer + off);
void setup () {
  Serial.begin(57600);
  Serial.println("\n[getStaticIP]");
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
  ether.staticSetup(myip, gwip);
  ether.copyIp(ether.hisip, hisip);
  ether.printIp("Server: ", ether.hisip);
  while (ether.clientWaitingGw())
    ether.packetLoop(ether.packetReceive());
  Serial.println("Gateway found");
  timer = - REQUEST_RATE; // start timing out right away
void loop () {
  if (millis() > timer + REQUEST_RATE) {
    timer = millis();
    Serial.println("\n>>> REQ");
    ether.browseUrl(PSTR("#sclient=psy-ab&q=enc28j60+arduino+wiring"), "", website, &my_result_cb);
    Serial.println("\ndone>>>");
here is the output in the serial monitor:
My IP: 192.168.0.203
Netmask: 255.255.255.0
Server: 192.168.0.242
Pinging: 192.168.0.242
Sending a request...
and it just continues with pinging and sending a request .... If I run the webclient sketch example that comes with the ethercard library it does the same kind of thing it never runs the my_callback only returns <<< REQ in the serial monitor
Is there anyone on here that may be able to point me in the right direction because I can not get this to work and I am almost bald because of it. There has to be a way to do it but everything I have tried does not work, I am not sure if I am using the same version of library or what but no matter how many examples I've tried I can't get any to work. Not even the example with the ethercard library. I can setup a webserver on the arduino that works fine though.
WAMP... Windows... Microsoft Firewall with Advanced Security...
Am I on the right track?
If so, go into MFAS and add a rule to open the inbound HTTP port. It will be blocked by default. Could just as easily be blocked by whatever other security/antivirus package you may b erunning.
I cursed the Wiznet W5100 and Ethernet library until I discovered that was the culprit when I first played around with them. I could ping from the PC to my arduino but the other direction... Nada.
ddowney:
While I also think this is a networking/firewall-issue you might want to checkout this library that allows you to run the Arduino-Ethernet-Webclient-example (the one that comes with the IDE) on ENC28J60 boards: GitHub - ntruchsess/arduino_uip: UIPEthernet: A plugin-replacement of the stock Arduino Ethernet library for ENC28J60 shields and breakout boards. Full support for persistent (streaming) TCP-connections and UDP (Client and Server each), ARP, ICMP, DHCP and DNS. Build around Adam Dunkels uIP Stack. Further developed version can be found on https://github.com/UIPEthernet/UIPEthernet
  • Norbert
