Hello All,
Could someone please help I want to use the alarm library to trigger some specific functions in my project. The below code is just a simplified example to highlight the issues im having. For starters what I want to do is trigger an alarm to execute some code I also want to.
- Identify the alarm ID that is triggered can't get it to work with Alarm. getTriggeredAlarmId()
- Disable the alarm at will with code. then enable or reset it to trigger again when called again
Below is a poor attempt at doing that (doesn't work). any direction, help or examples would be greatly appreciated.
#include <Time.h>
#include <TimeAlarms.h>
int nowSecondAlarm ;
const int PB = 2;
int LED13 = 13;
AlarmID_t myTimer;
pinMode(LED13, OUTPUT);
pinMode(PB, INPUT);
setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
myTimer = Alarm.timerRepeat(15, Blinker); // timer for every 15 seconds
Alarm.timerOnce(30, OnceOnly); // called once after 10 seconds
void loop(){
digitalClockDisplay();
AlarmId ID = Alarm. getTriggeredAlarmId();
Serial.println(ID);
Alarm.delay(1000);
Alarm.delay(1000); // wait one second between clock display
void Repeats(){
Serial.println("15 second timer");
void OnceOnly(){
Serial.println("This timer only triggers once");
Alarm.disable( myTimer);
void digitalClockDisplay()
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void Blinker() {
Serial.print("alarm triggered");
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
All your code needs to be in a function.
I changed a little bit your code to try to show you what you are doing wrong:
#include <Time.h>
const int PB = 2;
int LED13 = 13;
AlarmID_t timerBliker;
AlarmID_t timerOnceOnly;
pinMode(PB, INPUT);
timerBliker = Alarm.timerRepeat(15, Blinker); // timer for every 15 seconds
timerOnceOnly = Alarm.timerOnce(30, OnceOnly); // called once after 10 seconds
Serial.print("timerBliker: ");
Serial.println(timerBliker);
Serial.print("timerOnceOnly: ");
Serial.println(timerOnceOnly);
void loop(){
AlarmID_t ID = Alarm. getTriggeredAlarmId();
Serial.println(ID);
Alarm.delay(1000);
void Repeats(){
void OnceOnly(){
Serial.println(ID);
Alarm.disable(timerBliker);
Serial.println(ID);
Serial.print(":");
if(digits < 10)
Serial.print('0');
void Blinker() {
Serial.println(ID);
Serial.println("alarm triggered");
Now, you can see the correct AlarmID (when the alarm is created and when the the alarm is triggered - inside the function that is called after the alarm is triggered). And you can see the "blinker alarm" being disable after the line:
Awesome response luisilva Very helpful. I played with the code a bit more trying to understand how this library works. Would you or anyone else know how to reset a "once only" alarm I get a repeat alarm to reset with a different cycle time but the once only is a little more stubborn it seems.
Alarm.enable(timerOnceOnly);
Alarm.write(1, 8 ) ; // - write the value (and enable) the alarm for the given ID
is not working out.
#include <Time.h>
const int PB = 2;
int LED13 = 13;
AlarmID_t timerOnceReset;
pinMode(PB, INPUT);
timerBliker = Alarm.timerRepeat(5, Blinker); // timer for every 15 seconds
timerOnceOnly = Alarm.timerOnce(9, OnceOnly); // called once after 10 seconds
timerOnceReset = Alarm.timerRepeat(14, Reset); // timer for every 15 seconds
Serial.print("timerOnceReset: ");
Serial.println(timerOnceReset);
void loop(){
//AlarmID_t ID = Alarm. getTriggeredAlarmId();
// Serial.println(ID);
// Alarm.delay(1000);
void Reset(){
Serial.println("reset blinker alarm");
Alarm.write(0, 5); // - write the value (and enable) the alarm for the given ID
Serial.println("disable once alarm");
Alarm.delay (100);
Alarm.disable(timerOnceOnly);
Serial.println("Reset once alarm");
Alarm.delay (100);
Alarm.write(1, 8); // - write the value (and enable) the alarm for the given ID
void OnceOnly(){
Serial.print(ID);
Serial.println("...ID OnceOnly");
Serial.println("This timer only triggers once and Blinker Diable");
digitalWrite(13, LOW); // turn the LED OFF
// AlarmID_t ID = Alarm. getTriggeredAlarmId();
//Serial.print(ID);
//Serial.println("...IDa");
Alarm.delay(0);
Serial.print(":");
if(digits < 10)
Serial.print('0');
void Blinker() {
Serial.println("timerBliker alarm triggered");
Serial.print(ID);
Serial.println("...ID Blinker");
Alarm.delay (500);
Alarm.delay (500);
For what I see you are trying to "enable" a timer that only repeat once ad that was already triggered. So, as it was already triggered it wouldn't not trigger again. I don't know if it make sense to you. Try to do that to a "timerRepeat" or create another "timerOnce".
Thanks Again!!!!! I got what I needed to work in the below. Now I can apply what I learned to something useful. Cheers.
#include <Time.h>
const int buttonPin = 2;
const int LED13 = 13;
int buttonState = 0;
pinMode(buttonPin, INPUT);
timerBliker = Alarm.timerRepeat(3, Blinker); // timer for every 15 seconds
void loop(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH){
Serial.println("*******ALARMS DISABLED****************");
Alarm.enable(timerBliker);
Alarm.disable(timerOnceReset);
void Reset(){
Alarm.delay (100);
Alarm.delay (100);
int period = random(3,10); // get a new random period
Alarm.timerOnce(period, OnceOnly); // trigger for another random period
void OnceOnly(){
Serial.print(ID);
//Serial.print(ID);
Alarm.delay(0);
Serial.print(":");
if(digits < 10)
Serial.print('0');
void Blinker() {
Serial.print(ID);
Alarm.enable (timerOnceOnly);
Alarm.delay (500);
digitalWrite(13, LOW); // turn the LED on (HIGH is the voltage level)
Alarm.delay (500);
One more thing. The manes of the variables (and functions) must be something meaningful. So, for things like:
you must create names like:
timerReset = Alarm.timerRepeat(14, Reset); // timer for every 15 seconds
or:
timerRepeatReset = Alarm.timerRepeat(14, Reset); // timer for every 15 seconds
Fair point, Bit messy on my part for sure. Also doesn't help with future understanding of the code for me or any one else.
Thanks again.
