Help please with this code
I have tried to make this code work hundreds of times, but I fail, please help me!
I injected a ppm signal from a remote control (trainer jack port) on pin 2 on arduino pro mini, as written in the code.
at arduino outputs 3, 4, 5 … I connected servo, but it does not work
I want to say that the code is not written by me, I tried to make it work
Thank you very much!
/*This program puts the servo values into an array,
 reagrdless of channel number, polarity, ppm frame length, etc...
 You can even change these while scanning!*/
#define PPM_Pin 2  //this must be 2 or 3
#define multiplier (F_CPU/8000000)  //leave this alone
int ppm[16];  //array for storing up to 16 servo signals
byte servo[] = {1,4,5,6,7,8,9,10};  //pin number of servo output
#define servoOut  //comment this if you don't want servo output
//#define DEBUG
  Serial.println("ready");
  #if defined(servoOut)
  for(byte i=0; sizeof(servo)-1; i++) pinMode(servo[i], OUTPUT);
  #endif
  pinMode(PPM_Pin, INPUT);
  attachInterrupt(PPM_Pin - 2, read_ppm, CHANGE);
  TCCR1A = 0;  //reset timer1
  TCCR1B = 0;
  TCCR1B |= (1 << CS11);  //set timer1 to increment every 0,5 us
  //You can delete everithing inside loop() and put your own code here
  int count;
  while(ppm[count] != 0){  //print out the servo values
    Serial.print(ppm[count]);
    Serial.print("  ");
    count++;
  Serial.println("");
  delay(100);  //you can even use delays!!!
void read_ppm(){  //leave this alone
  static unsigned int pulse;
  static unsigned long counter;
  static byte channel;
  static unsigned long last_micros;
  counter = TCNT1;
  TCNT1 = 0;
  if(counter < 710*multiplier){  //must be a pulse if less than 710us
    pulse = counter;
    if(sizeof(servo) > channel) digitalWrite(servo[channel], HIGH);
    if(sizeof(servo) >= channel && channel != 0) digitalWrite(servo[channel-1], LOW);
    #endif
  else if(counter > 1910*multiplier){  //sync pulses over 1910us
    channel = 0;
    #if defined(DEBUG)
    Serial.print("PPM Frame Len: ");
    Serial.println(micros() - last_micros);
    last_micros = micros();
    #endif
  else{  //servo values between 710us and 2420us will end up here
    ppm[channel] = (counter + pulse)/multiplier;
    #if defined(DEBUG)
    Serial.print(ppm[channel]);
    Serial.print("  ");
    #endif
    channel++;
Did you forget something here?
byte servo[] = {1,4,5,6,7,8,9,10}; Pin 3 would be a problem, as would pin 1
Do you still have the original code?
I’m not sure of the polarity of the pulses on the trainer port, but I’d be inclined to flip-flop the interrupt between RISING and FALLING within the ISR, so it’s easier to see if you’re in a pulse or an inter-pulse gap, and advance the channel pointer only when you get a long sync.
yes, original code is here
ppm polarity is negative, I use Hitec
But that code doesn’t output to pin 3 either.
Did you try simply changing the “servo” array to only use the pins you’re interested in?
I connected 3 servo to pins 4,5 and 6
I injected a ppm signal on pins 2 and 3
That’s not what you wrote originally.
Compiled, but untested. (the github code was junk too)
byte servo[] = {3};                 //pin number of servo output
const byte nChannels = sizeof (servo) / sizeof (servo [0]);
  for(byte i = 0; i < nChannels; i++) {
    pinMode(servo [i], OUTPUT);
    digitalWrite (servo [i], LOW);
  attachInterrupt(digitalPinToInterrupt (PPM_Pin), read_ppm, CHANGE);
  TCCR1B = 0;
void read_ppm()
  counter = TCNT1;
  TCNT1 = 0;
    if(channel < nChannels)
      digitalWrite (servo [channel], HIGH);
    if(channel <= nChannels && channel != 0)
      digitalWrite (servo [channel-1], LOW);
    channel = 0;
  else {  //servo values between 710us and 2420us will end up here
     channel++;
can you modify it to work?
By that, I assume you tried my code with a servo on pin 3, and nothing happened?
I don’t have any hardware to test it.
Time to get your oscilloscope out.
yes, yes it works. :slight_smile:
but it works weird, when I move the stick to the left, it works perfectly normal, but when I move it to the right it makes a 180 degree turn alone
