In a sketch I got from a friend I have the following error message:
EtherCard.h: error: expected class-name beore ´{´ token class EtherCard : public Ethernet {
I know it has something to do with the library I am using but how could I fix the problem. It is the ethercard-master library and I tried downloads from several sources allready but it is always the same message.
sketch_oct02a:49: error: variable or field 'homePage' declared void
sketch_oct02a:49: error: 'BufferFiller' was not declared in this scope
sketch_oct02a:49: error: 'buf' was not declared in this scope
sketch_oct02a:25: error: 'Ethernet' has not been declared
sketch_oct02a:41: error: 'BufferFiller' does not name a type
sketch_oct02a.ino: In function 'void setup()':
sketch_oct02a:406: error: 'ether' was not declared in this scope
sketch_oct02a:406: error: 'Ethernet' has not been declared
sketch_oct02a.ino: In function 'void loop()':
sketch_oct02a:822: error: 'ether' was not declared in this scope
sketch_oct02a:873: error: 'freeMemory' was not declared in this scope
sketch_oct02a.ino: In function 'void EthernetSendUDP(uint8_t)':
sketch_oct02a:894: error: 'ether' was not declared in this scope
sketch_oct02a.ino: At global scope:
sketch_oct02a:920: error: variable or field 'homePage' declared void
sketch_oct02a:920: error: 'BufferFiller' was not declared in this scope
sketch_oct02a:920: error: 'buf' was not declared in this scope
Now, I don't have the EtherCard library installed. Partly because I don't have an ENCxxxxx-chipped ethernet card, and partly because you didn't provide a link to the library.
Ok thank you shall I post the library I am using?
And I also have the same messages when I try to compile except the ones that connect to the ENC...
I need to say that I didn´t write the code I got it from a user who has the same Automationsystem than I do. Sine he already helped me a lot I want to give him a little pause and also it is better for my understanding if I (at least try) too figure it out "myself".
I attached the library to the message
After installing the library, I now get these errors:
sketch_oct02a.ino: In function 'void homePage(BufferFiller&)':
sketch_oct02a:935: error: 'freeMemory' was not declared in this scope
Ok Paul I thank you very much I´ll get in contact with the autor of the sketch I guess he got it running on his system. Do you mean the funcntion "freeMemory"? Sorry if I ask stupid questions but I´m trying to learn and its hard for a beginner. I come from step7 and this is totally different. S7 is drawing compared to arduino.
