help please
Is there anyone who can help me with a code from which I can navigate between two point gps using an hmc compass, GPS shield and arduino uno
A good GPS library will have a "bearingTo" method (name may differ).
i need to calculate the distance between two gps coordinate
i have test this programme but it's dose'ent march
float calc_distance(float flat1, float flon1, float flat2, float flon2)
 float diflon;
 float dist;
 float a;
 float b;
 int R = 6371000;
 flat1 = radians(flat1);
 flat2 = radians(flat2);
 diflon = radians((flon2)-(flon1));
 a = sin(flat1)*sin(flat2);
 b = cos(flat1)*cos(flat2)*cos(diflon);
 dist = acos(a+b)*R;
 return dist;
If you post the complete program and details of exactly what components you're using someone may be able to help.
The only thing I can immediately see in the fragment you've posted is that the value you use for R is way too big for an int. I don't know if that has anything to do with whatever the problem is that you're seeing.
Steve
