my lcd 20x4 display @ next to the number I did all the wiring but still show me the same problem
I need your suggestion please.
I daresay we will never know what the problem is, because only you know what code you wrote.
OK, here's what you do.
First read the instructions on how to post questions.
Then post your code using the "copy code for forum" option in the IDE after you have used "Auto Format" - control-T.
And explain what you expect your code to do.
the code should show time, date and temperature and have two alarms
their is no error when I download the code but the above picture what display on the screen instead of the real numbers.
here is the code
// include LCD library code
#include <LiquidCrystal.h>
// include Wire library code (needed for I2C protocol devices)
#include <Wire.h>
// LCD module connections (RS, E, D4, D5, D6, D7)
LiquidCrystal lcd(3, 4, 5, 6, 7, 8);
const int button1 = 9; // button1 pin number
const int button2 = 10; // button1 pin number
const int button3 = 11; // button1 pin number
const int alarm_pin = 12; // Alarms pin number
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
pinMode(12, OUTPUT);
digitalWrite(alarm_pin, LOW);
// set up the LCD's number of columns and rows
lcd.begin(20, 4);
Wire.begin(); // Join i2c bus
attachInterrupt(digitalPinToInterrupt(2), Alarm, FALLING);
// Variables declaration
bool alarm1_status, alarm2_status;
char Time[] = " : : ",
calendar[] = " / /20 ",
alarm1[] = "A1: : :00", alarm2[] = "A2: : :00",
temperature[] = "T: . C";
byte i, second, minute, hour, day, date, month, year,
alarm1_minute, alarm1_hour, alarm2_minute, alarm2_hour,
status_reg;
void Alarm(){
digitalWrite(alarm_pin, HIGH);
void DS3231_read(){ // Function to read time & calendar data
Wire.beginTransmission(0x68); // Start I2C protocol with DS3231 address
Wire.write(0); // Send register address
Wire.endTransmission(false); // I2C restart
Wire.requestFrom(0x68, 7); // Request 7 bytes from DS3231 and release I2C bus at end of reading
second = Wire.read(); // Read seconds from register 0
minute = Wire.read(); // Read minuts from register 1
hour = Wire.read(); // Read hour from register 2
day = Wire.read(); // Read day from register 3
date = Wire.read(); // Read date from register 4
month = Wire.read(); // Read month from register 5
year = Wire.read(); // Read year from register 6
void alarms_read_display(){ // Function to read and display alarm1, alarm2 and temperature data
byte control_reg, temperature_lsb;
char temperature_msb;
Wire.write(0x08); // Send register address
Wire.requestFrom(0x68, 11); // Request 11 bytes from DS3231 and release I2C bus at end of reading
alarm1_minute = Wire.read(); // Read alarm1 minutes
alarm1_hour = Wire.read(); // Read alarm1 hours
Wire.read(); // Skip alarm1 day/date register
alarm2_minute = Wire.read(); // Read alarm2 minutes
alarm2_hour = Wire.read(); // Read alarm2 hours
Wire.read(); // Skip alarm2 day/date register
control_reg = Wire.read(); // Read the DS3231 control register
status_reg = Wire.read(); // Read the DS3231 status register
Wire.read(); // Skip aging offset register
temperature_msb = Wire.read(); // Read temperature MSB
temperature_lsb = Wire.read(); // Read temperature LSB
// Convert BCD to decimal
alarm1_minute = (alarm1_minute >> 4) * 10 + (alarm1_minute & 0x0F);
alarm1_hour = (alarm1_hour >> 4) * 10 + (alarm1_hour & 0x0F);
alarm2_minute = (alarm2_minute >> 4) * 10 + (alarm2_minute & 0x0F);
alarm2_hour = (alarm2_hour >> 4) * 10 + (alarm2_hour & 0x0F);
// End conversion
alarm1[8] = alarm1_minute % 10 + 48;
alarm1[7] = alarm1_minute / 10 + 48;
alarm1[5] = alarm1_hour % 10 + 48;
alarm1[4] = alarm1_hour / 10 + 48;
alarm2[8] = alarm2_minute % 10 + 48;
alarm2[7] = alarm2_minute / 10 + 48;
alarm2[5] = alarm2_hour % 10 + 48;
alarm2[4] = alarm2_hour / 10 + 48;
alarm1_status = bitRead(control_reg, 0); // Read alarm1 interrupt enable bit (A1IE) from DS3231 control register
alarm2_status = bitRead(control_reg, 1); // Read alarm2 interrupt enable bit (A2IE) from DS3231 control register
if(temperature_msb < 0){
temperature_msb = abs(temperature_msb);
temperature[2] = '-';
temperature[2] = ' ';
temperature_lsb >>= 6;
temperature[4] = temperature_msb % 10 + 48;
temperature[3] = temperature_msb / 10 + 48;
if(temperature_lsb == 0 || temperature_lsb == 2){
temperature[7] = '0';
if(temperature_lsb == 0) temperature[6] = '0';
else temperature[6] = '5';
if(temperature_lsb == 1 || temperature_lsb == 3){
temperature[7] = '5';
if(temperature_lsb == 1) temperature[6] = '2';
else temperature[6] = '7';
temperature[8] = 223; // Put the degree symbol
lcd.setCursor(10, 0);
lcd.print(temperature); // Display temperature
lcd.setCursor(0, 2);
lcd.print(alarm1); // Display alarm1
lcd.setCursor(17, 2);
if(alarm1_status) lcd.print("ON "); // If A1IE = 1 print 'ON'
else lcd.print("OFF"); // If A1IE = 0 print 'OFF'
lcd.setCursor(0, 3);
lcd.print(alarm2); // Display alarm2
lcd.setCursor(17, 3);
if(alarm2_status) lcd.print("ON "); // If A2IE = 1 print 'ON'
else lcd.print("OFF"); // If A2IE = 0 print 'OFF'
void calendar_display(){ // Function to display calendar
switch(day){
case 1: strcpy(calendar, "Sun / /20 "); break;
case 2: strcpy(calendar, "Mon / /20 "); break;
case 3: strcpy(calendar, "Tue / /20 "); break;
case 4: strcpy(calendar, "Wed / /20 "); break;
case 5: strcpy(calendar, "Thu / /20 "); break;
case 6: strcpy(calendar, "Fri / /20 "); break;
case 7: strcpy(calendar, "Sat / /20 "); break;
default: strcpy(calendar, "Sat / /20 ");
calendar[13] = year % 10 + 48;
calendar[12] = year / 10 + 48;
calendar[8] = month % 10 + 48;
calendar[7] = month / 10 + 48;
calendar[5] = date % 10 + 48;
calendar[4] = date / 10 + 48;
lcd.setCursor(0, 1);
lcd.print(calendar); // Display calendar
the rest of the code
void DS3231_display(){
second = (second >> 4) * 10 + (second & 0x0F);
minute = (minute >> 4) * 10 + (minute & 0x0F);
hour = (hour >> 4) * 10 + (hour & 0x0F);
date = (date >> 4) * 10 + (date & 0x0F);
month = (month >> 4) * 10 + (month & 0x0F);
year = (year >> 4) * 10 + (year & 0x0F);
// End conversion
Time[7] = second % 10 + 48;
Time[6] = second / 10 + 48;
Time[4] = minute % 10 + 48;
Time[3] = minute / 10 + 48;
Time[1] = hour % 10 + 48;
Time[0] = hour / 10 + 48;
calendar_display(); // Call calendar display function
lcd.setCursor(0, 0);
lcd.print(Time); // Display time
void Blink(){
byte j = 0;
while(j < 10 && (digitalRead(button1) || i >= 5) && digitalRead(button2) && (digitalRead(button3) || i < 5)){
j++;
delay(25);
byte edit(byte x, byte y, byte parameter){
char text[3];
while(!digitalRead(button1) || !digitalRead(button3)); // Wait until button B1 is released
while(true){
while(!digitalRead(button2)){ // If button B2 is pressed
parameter++;
if(((i == 0) || (i == 5)) && parameter > 23) // If hours > 23 ==> hours = 0
parameter = 0;
if(((i == 1) || (i == 6)) && parameter > 59) // If minutes > 59 ==> minutes = 0
parameter = 0;
if(i == 2 && parameter > 31) // If date > 31 ==> date = 1
parameter = 1;
if(i == 3 && parameter > 12) // If month > 12 ==> month = 1
parameter = 1;
if(i == 4 && parameter > 99) // If year > 99 ==> year = 0
parameter = 0;
if(i == 7 && parameter > 1) // For alarms ON or OFF (1: alarm ON, 0: alarm OFF)
parameter = 0;
lcd.setCursor(x, y);
if(i == 7){ // For alarms ON & OFF
if(parameter == 1) lcd.print("ON ");
else{
sprintf(text,"%02u", parameter);
lcd.print(text);
if(i >= 5){
DS3231_read(); // Read data from DS3231
DS3231_display(); // Display DS3231 time and calendar
delay(200); // Wait 200ms
lcd.print(" "); // Print two spaces
if(i == 7) lcd.print(" "); // Print space (for alarms ON & OFF)
Blink(); // Call Blink function
else{
lcd.print(text);
Blink();
if(i >= 5){
DS3231_read();
DS3231_display();}
if((!digitalRead(button1) && i < 5) || (!digitalRead(button3) && i >= 5)){
i++; // Increment 'i' for the next parameter
return parameter; // Return parameter value and exit
if(!digitalRead(button1)){ // If B1 button is pressed
i = 0;
hour = edit(0, 0, hour);
minute = edit(3, 0, minute);
while(!digitalRead(button1)); // Wait until button B1 released
while(true){
while(!digitalRead(button2)){ // If button B2 button is pressed
day++; // Increment day
if(day > 7) day = 1;
calendar_display(); // Call display_calendar function
delay(200);
lcd.print(" "); // Print 3 spaces
Blink();
lcd.print(calendar); // Print calendar
if(!digitalRead(button1)) // If button B1 is pressed
date = edit(4, 1, date); // Edit date
month = edit(7, 1, month); // Edit month
year = edit(12, 1, year); // Edit year
// Convert decimal to BCD
minute = ((minute / 10) << 4) + (minute % 10);
hour = ((hour / 10) << 4) + (hour % 10);
date = ((date / 10) << 4) + (date % 10);
month = ((month / 10) << 4) + (month % 10);
year = ((year / 10) << 4) + (year % 10);
// End conversion
// Write time & calendar data to DS3231 RTC
Wire.write(0); // Reset sesonds and start oscillator
Wire.write(minute); // Write minute
Wire.write(hour); // Write hour
Wire.write(day); // Write day
Wire.write(date); // Write date
Wire.write(month); // Write month
Wire.write(year); // Write year
Wire.endTransmission(); // Stop transmission and release the I2C bus
delay(200);
if(!digitalRead(button3)){ // If B3 button is pressed
while(!digitalRead(button3)); // Wait until button B3 released
i = 5;
alarm1_hour = edit(4, 2, alarm1_hour);
alarm1_minute = edit(7, 2, alarm1_minute);
alarm1_status = edit(17, 2, alarm1_status);
i = 5;
alarm2_hour = edit(4, 3, alarm2_hour);
alarm2_minute = edit(7, 3, alarm2_minute);
alarm2_status = edit(17, 3, alarm2_status);
alarm1_minute = ((alarm1_minute / 10) << 4) + (alarm1_minute % 10);
alarm1_hour = ((alarm1_hour / 10) << 4) + (alarm1_hour % 10);
alarm2_minute = ((alarm2_minute / 10) << 4) + (alarm2_minute % 10);
alarm2_hour = ((alarm2_hour / 10) << 4) + (alarm2_hour % 10);
// Write alarms data to DS3231
Wire.write(7); // Send register address (alarm1 seconds)
Wire.write(0); // Write 0 to alarm1 seconds
Wire.write(alarm1_minute); // Write alarm1 minutes value to DS3231
Wire.write(alarm1_hour); // Write alarm1 hours value to DS3231
Wire.write(0x80); // Alarm1 when hours, minutes, and seconds match
Wire.write(alarm2_minute); // Write alarm2 minutes value to DS3231
Wire.write(alarm2_hour); // Write alarm2 hours value to DS3231
Wire.write(0x80); // Alarm2 when hours and minutes match
Wire.write(4 | alarm1_status | (alarm2_status << 1)); // Write data to DS3231 control register (enable interrupt when alarm)
Wire.write(0); // Clear alarm flag bits
if(!digitalRead(button2) && digitalRead(alarm_pin)){ // When button B2 pressed with alarm (Reset and turn OFF the alarm)
digitalWrite(alarm_pin, LOW); // Turn OFF the alarm indicator
Wire.write(0x0E); // Send register address (control register)
// Write data to control register (Turn OFF the occurred alarm and keep the other as it is)
Wire.write(4 | (!bitRead(status_reg, 0) & alarm1_status) | ((!bitRead(status_reg, 1) & alarm2_status) << 1));
DS3231_read(); // Read time and calendar parameters from DS3231 RTC
alarms_read_display(); // Read and display alarms parameters
DS3231_display(); // Display time & calendar
delay(50); // Wait 50ms
// End of code
Wow! That is a serious bit of code there!
I am curious as to why you have an attachInterrupt in there; that appears unlikely to be necessary.
I have a strong feeling that the problem is in the formatting of the "sprintf" function.
"I daresay we will never know what the problem is, because only you know what code you wrote."
We also do not know what number you expect to see where the '@' symbols appear, nor do we know what the magic numbers in your program are supposed to be accomplishing although we can sometimes guess.
The fact that you get the same incorrect character every time, and the fact that it always precedes a value that you have extracted from the RTC, leads me to suspect that you might be retrieving the information incorrectly or that one of your magic numbers isn't doing what you expect it to.
The fact that the ASCII code for '@' is decimal 60 may not be as much help as knowing that it's hex value is 40 and therefore it's binary value is 01000000. Note that only one bit is high, and that it is a fairly high bit, which may be a clue. It's been a while since I dealt with the DS3231 at the register level but I suspect that you might not be masking off one of the flags that is packed in with the value when you extract your data.
It would help if you 'set' the RTC to a time that has different characters in each location. Trying to interpret what is going wrong with an incorrect display of 05:05:05 on May 5, 2015 is a lot harder than trying to interpret an incorrect display of 07:02:03 on April 5, 2018.
Don
floresta:
It's not 60. It's 64.
That it is.
My error kind of reinforces the absurdity of using decimal numbers to deal with ASCII codes, something I don't do voluntarily.
Don
