Help Porting Wireless Bootloader to MEGA (1280)?
Hey guys…
Anyone want to help me tackle this project of porting this bootloader to MEGA 1280?
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=122
I’ve got it working some what… it’s accepting the bytes from the Streamer and completes… however… it’s not actually starting the program. Wonder if it’s some fuse setting or the makefile changes (don’t think so) or the actually bootloader (highly likely).
This should be a quick port… just need another set of eye on it… We could post results on the Sparkfun site.
Danny
Changes I made for it to work on MEGA 1280 (still not working 100% – won’t start the program):
#include <avr/io.h>
#include <avr/boot.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
//Define baud rate
#define BAUD   19200 //Works with internal osc
//#define BAUD   38400 //Works with internal osc
//#define BAUD   57600 //Does not work with internal osc
#define MYUBRR (((((CPU_SPEED * 10) / (16L * BAUD)) + 5) / 10) - 1)
//Here we calculate the wait period inside getch(). Too few cycles and the XBee may not be able to send the character in time. Too long and your sketch will take a long time to boot after powerup.
#define CPU_SPEED      16000000
#define MAX_CHARACTER_WAIT      15 //10 works. 20 works. 5 throws all sorts of retries, but will work.
#define MAX_WAIT_IN_CYCLES ( ((MAX_CHARACTER_WAIT * 8) * CPU_SPEED) / BAUD )
//I have found that flow control is not really needed with this implementation of wireless bootloading.
//Adding flow control for wireless support
//#define sbi(port_name, pin_number)   (port_name |= 1<<pin_number)
//#define cbi(port_name, pin_number)   (port_name &= (uint8_t)~(1<<pin_number))
//#define CTS            2 //This is an input from the XBee. If low, XBee is busy - wait.
//#define RTS            3 //This is an output to the XBee. If we're busy, pull line low to tell XBee not to transmit characters into ATmega's UART
#define TRUE      0
#define FALSE      1
//Status LED
/* Onboard LED is connected to pin PB7 (e.g. Crumb128, PROBOmega128, Savvy128, Arduino Mega) */
#define LED_DDR  DDRB
#define LED_PORT PORTB
#define LED_PIN  PINB
#define LED      PINB7
//Function prototypes
void putch(char);
char getch(void);
void flash_led(uint8_t);
void onboard_program_write(uint32_t page, uint8_t *buf);
void (*app_start)(void) = 0x0000;
//Variables
uint8_t incoming_page_data[256];
uint8_t page_length;
uint8_t retransmit_flag = FALSE;
union page_address_union {
      uint16_t word;
      uint8_t  byte[2];
} page_address;
int main(void)
      uint8_t check_sum = 0;
      uint16_t i;
    //Setup USART baud rate
    UBRR0H = MYUBRR >> 8;
    UBRR0L = MYUBRR;
    UCSR0A = 0x00;
      UCSR0C = 0x06;
      //UCSR0B = _BV(TXEN0)|_BV(RXEN0);
    UCSR0B = (1<<RXEN0)|(1<<TXEN0);
    /* Enable internal pull-up resistor on pin D0 (RX), in order
            to supress line noise that prevents the bootloader from
            timing out (DAM: 20070509) */
            /* feature added to the Arduino Mega --DC: 080930 */
            DDRE &= ~_BV(PINE0);
      PORTE |= _BV(PINE0);
      //set LED pin as output
      LED_DDR |= _BV(LED);
      //flash onboard LED to signal entering of bootloader
      flash_led(1);
      //Start bootloading process
      putch(5); //Tell the world we can be bootloaded
      //Check to see if the computer responded
      uint32_t count = 0;
      while(!(UCSR0A & _BV(RXC0)))
            count++;
            if (count > MAX_WAIT_IN_CYCLES)
                  app_start();
      if(UDR0 != 6) app_start(); //If the computer did not respond correctly with a ACK, we jump to user's program
      while(1)
            //Determine if the last received data was good or bad
        if (check_sum != 0) //If the check sum does not compute, tell computer to resend same line
RESTART:
            putch(7); //Ascii character BELL
            putch('T'); //Tell the computer that we are ready for the next line
        while(1) //Wait for the computer to initiate transfer
                  if (getch() == ':') break; //This is the "gimme the next chunk" command
                  if (retransmit_flag == TRUE) goto RESTART;
        page_length = getch(); //Get the length of this block
        if (page_length == 'S') //Check to see if we are done - this is the "all done" command
                  boot_rww_enable (); //Wait for any flash writes to complete?
                  app_start();
            //Get the memory address at which to store this block of data
            page_address.byte[0] = getch(); if (retransmit_flag == TRUE) goto RESTART;
            page_address.byte[1] = getch(); if (retransmit_flag == TRUE) goto RESTART;
        check_sum = getch(); //Pick up the check sum for error dectection
            for(i = 0 ; i < page_length ; i++) //Read the program data
            incoming_page_data[i] = getch();
        //Calculate the checksum
            check_sum = check_sum + incoming_page_data[i];
        check_sum = check_sum + page_length;
        check_sum = check_sum + page_address.byte[0];
        check_sum = check_sum + page_address.byte[1];
        if(check_sum == 0) //If we have a good transmission, put it in ink
            onboard_program_write((uint32_t)page_address.word, incoming_page_data);
#define SPM_PAGESIZE 128
      uint16_t i;
      uint8_t sreg;
      // Disable interrupts.
      sreg = SREG;
      cli();
      eeprom_busy_wait ();
      boot_page_erase (page);
      boot_spm_busy_wait ();      // Wait until the memory is erased.
      for (i=0; i<SPM_PAGESIZE; i+=2)
            // Set up little-endian word.
            uint16_t w = *buf++;
            w += (*buf++) << 8;
            boot_page_fill (page + i, w);
      boot_page_write (page);     // Store buffer in flash page.
      boot_spm_busy_wait ();       // Wait until the memory is written.
      // Reenable RWW-section again. We need this if we want to jump back
      // to the application after bootloading.
      boot_rww_enable ();
      // Re-enable interrupts (if they were ever enabled).
      SREG = sreg;
void putch(char ch)
      //Adding flow control - xbee testing
      //while( (PIND & (1<<CTS)) != 0); //Don't send anything to the XBee, it is thinking
      while (!(UCSR0A & _BV(UDRE0)));
      UDR0 = ch;
char getch(void)
      //cbi(PORTD, RTS); //Tell XBee it is now okay to send us serial characters
      uint32_t count = 0;
            count++;
            if (count > MAX_WAIT_IN_CYCLES) //
                  retransmit_flag = TRUE;
      //sbi(PORTD, RTS); //Tell XBee to hold serial characters, we are busy doing other things
      return UDR0;
void flash_led(uint8_t count)
      uint8_t i;
      for (i = 0; i < count; ++i) {
            LED_PORT |= _BV(LED);
            //_delay_ms(100);
            LED_PORT &= ~_BV(LED);
            //_delay_ms(100);
Original working code for 328P is available here:
http://www.sparkfun.com/tutorial/WirelessBootloader/Wireless_Bootloader_ATmega328.c
So I have it now saving into the program space... however, it's not placing the bytes in the correct areas as shown below:
:20000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
:20002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
:20004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
:20006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
:200080000C942E010C942E010C942E010C942E010C9424030C942E010C942E010C942E01F0
:2000A0000C942E010C942E010C942E010C942E010C942E010C942E010C942E010C942E01C8
:2000C0000C942E010C942E010C942E010C9465030C942E010C942E010C94A6030C942E01F5
:2000E0000C942E0100002100240027002A002D003000330001010000040107010A010000F1
:20010000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
:20012000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF
:20014000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF
:20016000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F
:20018000204010204080020102010804020101020408102040808040201008040201800478
:2001A000020180402010080402010804020101020408102040800102040810204080000030
:2001C000090A02080B0C0D07060304010000000000000000000000000000000000000000C9
:2001E00000000000000000000000100F0E00000000000000000000000000000000000000D2
:20020000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE
:20022000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
:20024000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
:20026000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E
:2002800080E090E00E94AD018091070260E00E945802C80163E072E00E94F00668EE73E049
:2002A00080E090E00E94AD011F910F9108958091070261E00E9438028DE294E040E05BE4B8
:2002C00060E070E00E94E70308951F920F920FB60F9211242F933F938F939F93AF93BF93FC
:2002E0008091180290911902A0911A02B0911B0230911C020196A11DB11D232F2D5F2D37A8
:20030000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD
:20032000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD
:20034000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD
:20036000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D
Any ideas why?
I didn't look at this too closely, but maybe have a look at app_start compare it to the app_start in the arduino bootloader. I sort of remember this being an issue.
I've some what got it figured out now... it's how I am sending up the bytes to be stored in the program space memory. The 1280 uses 256 page size versus 128.
