HELP: Problem in uploading sketch
Dear all,
I have recently received my mega 2560.
I have tried the blink example, and modified the codes to do different things and it worked fine.. Then today I tried to program my arduino with WinAVR ( using C language) using AVR ISP usb programmer by pololu.. Again it works fine.
But the problem now is that I can not use the arduino IDE to upload my sketch..
Is there any idea why this happens?
When I tried to upload the sketch the IDE just keep trying to upload the chip but nothing happens..
Anyway I am using windows XP sp3 to do my stuffs
I really need advice as I am still a newbie
Thx Lev
Overwrote the bootloader? (when you uploaded with WinAVR + ISP)
@Coding Badly Is it possible that I overwrote the bootloader? Shouldn't it be written at the EEPROM? I wrote the code with WinAVR + ISP to the flash..
And how can I burn the bootloader into the chip again?
Thx
Yes.
No.
Flash is where any and all executable stuff resides in an AVR processor. That includes your application and the bootloader.
The Arduino IDE makes it fairly easy. Start here... http://www.arduino.cc/en/Hacking/Bootloader
@Coding Badly I tried the link that you gave me but it seems that the AVR ISP programmer not responding if I use the arduino IDE..
I found the link http://www.cbxdragbike.com/arduino/new/
and it gave me the bootloader hex file, I tried to upload it through AVR Studio and it says OK.. But I haven't yet been able to upload the sketches from arduino IDE..
Is what I'm doing right?
You have to upload the bootloader and set the processor’s fuses.
@Coding Badly
I haven't got any progress at all now..
When I tried to burn the bootloader through the arduino IDE, it gives result : avrdude: stk500_getsync(): not in sync: resp=0x00 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Then when I tried to follow the website and set the fuse, still there is nothing happening..
Can you please tell me how to fix it step by step?
Thx
I don't have the experience needed to give you detailed instructions.
Did you change the serial port to the ISP?
Anybody can give suggestions?
I still can't upload the sketches to the board up to now and I suspect I overwrote the bootloader when programming the board with WinAVR..
