Help - Problem with Green LED not staying lit
Hi! Can you please help me with my code?
I am trying to keep my Green light lit for as long as possible until the button is pressed which will then go to Yellow and Red and then back to Green again.
The code I have used is:
//declare LEDs
int red = 2;
int yellow = 6;
int green = 7;
//declare button
int btnPedestrian = 4;
pinMode(green, OUTPUT); //sets the digital pin 7 as OUTPUT
pinMode(yellow, OUTPUT); //sets the digital pin 6 as OUTPUT
pinMode(red, OUTPUT); //sets the digital pin 2 as OUTPUT
//turn LEDs off
digitalWrite(green, LOW);
digitalWrite(yellow, LOW);
digitalWrite(red, LOW);
//set the button to INPUT
pinMode(btnPedestrian, INPUT);
//For the serial monitor
while (digitalRead(4)==LOW)
digitalWrite(green, HIGH);
//digitalWrite(red, LOW);
//digitalWrite(green, HIGH);
/1/Serial.println("GREEN");
//greenLight();
//delay(3000);
//digitalWrite(green, LOW);
//digitalWrite(yellow, HIGH);
//Serial.println("\nYELLOW");
//delay(5000);
//digitalWrite(yellow, LOW);
//digitalWrite(red, HIGH);
//Serial.println("RED");
//delay(25000);
/*void greenLight(){
//checking for pedestrain button
for (int i = 1; i < 31; i++)
int state = digitalRead(btnPedestrian);
if (state==0)
Serial.print(i);
Serial.print(", ");
else if (state==1)
Serial.print("Pedestrian Crossing");
delay(5000);
return;
Please follow the advice given in the link below when posting code , use code tags and post the code here to make it easier to read and copy for examination
You have given a meaningful name to pin 4 but later
  while (digitalRead(4) == LOW)
You don't use the name. Why ? It is not a problem in itself but is sloppy
As to the code, what is keeping pin 4 LOW ?
Have you got a pulldown resistor in place keeping it a known state or is it floating at an unknown state, maybe HIGH, maybe LOW ?
consider
#undef MyHW
#ifdef MyHW
int red    = 11;
int yellow = 12;
int green  = 13;
int btnPedestrian = A1;
#else
//declare LEDs
int red = 2;
int yellow = 6;
int green = 7;
//declare button
#endif
    //turn LEDs off
    pinMode(btnPedestrian, INPUT_PULLUP);
    if (digitalRead(btnPedestrian)==LOW)
        delay(3000);
        delay(3000);
yes pull down resistor
presumably the other momentary switch terminal is connect to +V and the code should be checking for the input to be HIGH when checking if the switch is pressed in the code below
Recommend using internal pullup resistor and connect switch button to GND. Then button pressed is LOW.
