Today at 01:40 am
hello I am new to all this arduino and obviously programming I want to ask you for help with a project. I already have the programming so that a neo-m6v2 gps device and the sim800l send messages with the location but I want it to be activated when a menja is sent that says "activate" and that it stops sending a message when it says "Deactivate". Beforehand Thank you very much
This does not work for me
#include <TinyGPS.h>
#include <SoftwareSerial.h>
SoftwareSerial Gsm(7, 8);
char phone_no[] = "81xxxxxxx"; //replace with phone no. to get sms
TinyGPS gps; //Creates a new instance of the TinyGPS object
int enviar =0;
String Mensaje;
Gsm.begin(9600);
Gsm.println("AT+CMGF=1"); // Configurar el módulo en modo de texto
delay(500); //Tiempo de espera para que el modulo se conecte a una red
Gsm.println("AT+CNMI=2,2,0,0,0"); //Configuracion de la forma como recibir mensajes
Mensaje.reserve(100);
delay(10000);
if(Mensaje.indexOf ("Active") >= 0 || Mensaje.indexOf ("Star") >= 0)
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 2000;)
while (Serial.available())
char c = Serial.read();
Serial.print(c);
if (gps.encode(c))
newData = true;
if (newData) //If newData is true
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Gsm.print("AT+CMGF=1\r");
delay(800);
Gsm.print("AT+CMGS=\"");
Gsm.print(phone_no);
Gsm.println("\"");
delay(600);
Gsm.print("http://maps.google.com/maps?q=loc:");
// Gsm.print("Latitude = ");
Gsm.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
//Gsm.print(" Longitude = ");
Gsm.print(",");
Gsm.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
delay(400);
Gsm.println((char)26); // End AT command with a ^Z, ASCII code 26
delay(400);
Gsm.println();
delay(20000);
Serial.println(failed);
// if (chars == 0)
This yes, but I can not activate or deactivate it
Gsm.begin(9600);
for (unsigned long start = millis(); millis() - start < 4000;)
Serial.print(c);
if (gps.encode(c))
newData = true;
float flat, flon;
unsigned long age;
delay(1600);
Gsm.println("\"");
delay(1200);
Gsm.print(",");
delay(800);
delay(800);
Gsm.println();
delay(40000);
// if (chars == 0)
// Serial.println("** No characters received from GPS: check wiring **");
