Hi
I'm building a handbrake for my sim racing rig and need help with the code as i can't actually code myself.
These are the 2 parts i'm using
and
First i compiled and uploaded this sketch
//Analog Hall Sensor
//using an LM393 Low Power Low Offset Voltage Dual Comparator
- Analog Hall Sensor Uno R3
- A0 A0
- D0 7
- VCC 5V
- GND GND
const int ledPin = 13;//the led attach to pin13
int sensorPin = A0; // select the input pin for the potentiometer
int digitalPin=7; //D0 attach to pin7
int sensorValue = 0;// variable to store the value coming from A0
boolean digitalValue=0;// variable to store the value coming from pin7
pinMode(digitalPin,INPUT);//set the state of D0 as INPUT
pinMode(ledPin,OUTPUT);//set the state of pin13 as OUTPUT
Serial.begin(9600); // initialize serial communications at 9600 bps
sensorValue = analogRead(sensorPin); //read the value of A0
digitalValue=digitalRead(digitalPin); //read the value of D0
Serial.print("Sensor Value "); // print label to serial monitor
Serial.println(sensorValue); //print the value of A0
Serial.print("Digital Value "); // print label to serial monitor
Serial.println(digitalValue); //print the value of D0 in the serial
if( digitalValue==HIGH )//if the value of D0 is HIGH
digitalWrite(ledPin,LOW);//turn off the led
if( digitalValue==LOW)//else
digitalWrite(ledPin,HIGH);//turn on the led
delay(1000);//delay 200ms
And i can get a readout on the serial monitor.
I then installed the joystick library and ran the test code and i can see windows is recognising the arduino as a game controller.
I need windows to recognise the analog hall sensor as a throttle, and be plug and play so i don't have to mess about when starting a game. I think i'll also need the ability to adjust the range.
Can anyone help?
