Help..! Programming in Multitasking
I'm beginner in programming.. I'm just editing a open energy meter code and adding features to it..!
This open energy meter gives Current, Voltage and powerfactor output - 60 samples per second. in serial monitor of arduino ide.
I have added SD card module to this energy meter, so that it saves the Log file. But a problem is the large number of samples makes the sd card fill fast.
So i wanted multi tasking here.. There should not be any change in serial monitor - same 60 samples per second...
But in SD card, It should print one sample/ minute ...!!
So that it saves space in the SD card..! Can anyone help me with this ? Any idea ? I have attached the code below
Thanks in Advance
code.txt (22.5 KB)
Why do you think you need multitasking for this? Hint - you don't.
Count how many times you do a serial output. When the count reaches 60*60, send a value to the SD card.
If you choose to disregard @aarg's good advice you may be interested in the demo Several Things at a Time
...R
can u specify the statement as a code here@ aarg ?
How 60 * 60 ?
If number of samples varies per second ? what to do then ?
energymet:
How 60 * 60 ?
++sampleCount;
if (sampleCount > samplesPerSecond * SECONDS_PER_MINUTE)
  writeSD();
  sampleCount = 0;
aarg:
++sampleCount;
  writeSD();
  sampleCount = 0;
Thanks for the above code...Another problem
How to calculate samplesPerSecond and SECONDS_PER_MINUTE ?
Any libraries available or code for that ?
energymet:
Huh? Samples per second is a design decision - wait, you told us it was 60 - then you changed your mind. You can't even calculate how many seconds are in a minute. Some Abyssinian priest decided that 4000 years ago. How can the computer decide them? I suspect you haven't told us enough.
No in this program, the samples keep varying ... at one set of second it gives 60 samples.. at next set it gives 65 and goes on increasing and decreasing
I have included your piece of code with my program... but it throws error... Please check it, i have attached my program with this
thanks in advance
code.txt (22.8 KB)
I suspect people would be more willing to read your code if
a) It conformed to some sensible and consistent formatting scheme
b) it was reduced in size, by sensible use of arrays and loops.
Case in point
void sdwrite()
 File dataFile = SD.open("datalog.csv", FILE_WRITE);
  if (dataFile) {
    dataFile.print(rtc.getUnixTime(rtc.getTime()));
    dataFile.print(",");
    dataFile.print("CT1");
    dataFile.print(Vrms);
    dataFile.print(Irms1);
    dataFile.print(powerFactor5);
    dataFile.println();
    dataFile.print("CT2");
    dataFile.print(Irms2);
    dataFile.println();
    dataFile.print("CT3");
    dataFile.print(Irms3);
    dataFile.println();
    dataFile.print("CT4");
    dataFile.print(Irms4);
    dataFile.println();
    dataFile.print("CT5");
    dataFile.print(Irms5);
    dataFile.println();
    dataFile.print("CT6");
    dataFile.print(Irms6);
    dataFile.println();
    dataFile.print("CT7");
    dataFile.print(Irms7);
    dataFile.println();
    dataFile.print("CT8");
    dataFile.print(Irms8);
    dataFile.println();
    dataFile.print("CT9");
    dataFile.print(Irms9);
    dataFile.println();
    dataFile.print("CT10");
    dataFile.print(Irms10);
    dataFile.println();
    dataFile.close();
    Serial.println("error opening datalog.txt");
About 115 lines of code (and a lot of wasted precious RAM) should be about 25 lines of code.
AWOL:
yeah.. So only i couldn't able to understand this.. This Energy meter was invented and designed by a Scientist at National Institute of Electronics & Information Technology (NIELIT), India.. The main aim of this meter is working in low cost with sensors..! than the products out in market..!
I don't know .. what's wrong in this code... I have created two separate class to achieve multi processing at same time..
1st process: It has to show all the readings in the serial monitor of arduino ide in a interval of
"100"
2nd process: it should write 1 log entry in sd card in every 1 minute.. to save the space in sd card..!
but the problem is, 1st process works great.. in 2nd process, if i give 10000 millisecond - it works fine.. if i give 60000 millisec (1 min) its not at all creating even a log file.. Please help me in this regard..!
#include <stdlib.h>
#include <DS3231.h>
DS3231 rtc(SDA, SCL);
#include <SPI.h>
#include <SD.h>
#include <EasyScheduler.h>
#include <TaskScheduler.h>
const int chipSelect = 53;
const int nodeID = 0;
void t1Callback();
void t2Callback();
int sampleCount = 0;
Time t;
#define FILTERSETTLETIME 5000 // Time (ms) to allow the filters to settle before sending data
#define SERIALPRINT // include print statement for commissioning - comment this line to exclude
#define PHASE2 8 // Number of samples delay for L2
#define PHASE3 17 // Number of samples delay for L3, also size of array
// These can be adjusted if the phase correction is not adequate
//Set Voltage and current input pins
int inPinV = 0;
int inPinI1 = 1;
int inPinI2 = 2;
int inPinI3 = 3;
int inPinI4 = 4;
int inPinI5 = 5;
int inPinI6 = 1;
int inPinI7 = 2;
int inPinI8 = 3;
int inPinI9 = 4;
int inPinI10 = 5;
double Vcal = 228.289; // Calibration - constant for voltage input - for ideal power voltage adapter
double Ical1 = 134.00; // Calibration constant for current transformer 1
double Ical2 = 134.00; // Calibration constant for current transformer 2
double Ical3 = 134.00; // Calibration constant for current transformer 3
double Ical4 = 134.00; // Calibration constant for current transformer 4
double Ical5 = 134.00; // Calibration constant for current transformer 5
double Ical6 = 134.00; // Calibration constant for current transformer 1
double Ical7 = 134.00; // Calibration constant for current transformer 2
double Ical8 = 134.00; // Calibration constant for current transformer 3
double Ical9 = 134.00; // Calibration constant for current transformer 4
double Ical10 = 134.00; // Calibration constant for current transformer 5
double Phasecal1 = 1.00; // Calibration constant for phase shift L1
double Phasecal2 = 1.68; // Calibration constant for phase shift L2
double Phasecal3 = 1.00; // Calibration constant for phase shift L3
// Variable declaration for filters, phase shift, voltages, currents & powers
int lastSampleV,sampleV=0; //sample_ holds the raw analog read value, lastSample_ holds the last sample
int lastSampleI1,sampleI1=0;
int lastSampleI2,sampleI2=0;
int lastSampleI3,sampleI3=0;
int lastSampleI4,sampleI4=0;
int lastSampleI5,sampleI5=0;
int lastSampleI6,sampleI6=0;
int lastSampleI7,sampleI7=0;
int lastSampleI8,sampleI8=0;
int lastSampleI9,sampleI9=0;
int lastSampleI10,sampleI10=0;
double lastFilteredV,filteredV; //Filtered_ is the raw analog value minus the DC offset
double lastFilteredI1, filteredI1;
double lastFilteredI2, filteredI2;
double lastFilteredI3, filteredI3;
double lastFilteredI4, filteredI4;
double lastFilteredI5, filteredI5;
double lastFilteredI6, filteredI6;
double lastFilteredI7, filteredI7;
double lastFilteredI8, filteredI8;
double lastFilteredI9, filteredI9;
double lastFilteredI10, filteredI10;
double phaseShiftedV1; //Holds the calibrated delayed & phase shifted voltage.
double phaseShiftedV2;
double phaseShiftedV3;
double sqV,sumV,sqI1,sumI1,sqI2,sumI2,
sqI3,sumI3,sqI4,sumI4,sqI5,sumI5,
sqI6,sumI6,sqI7,sumI7,
sqI8,sumI8,sqI9,sumI9,sqI10,sumI10;
double instP1,sumP1,instP2,sumP2,instP3,sumP3,//sq = squared, sum = Sum, inst = instantaneous
instP4,sumP4,instP5,sumP5,instP6,sumP6,
instP7,sumP7,instP8,sumP8,instP9,sumP9,
instP10,sumP10;
int startV; //Instantaneous voltage at start of sample window.
double realPower1, // The final data
apparentPower1,
powerFactor1,
Irms1,
realPower2,
apparentPower2,
powerFactor2,
Irms2,
realPower3,
apparentPower3,
powerFactor3,
Irms3,
realPower4,
apparentPower4,
powerFactor4,
Irms4,
realPower5,
apparentPower5,
powerFactor5,
Irms5,
realPower6,
apparentPower6,
powerFactor6,
Irms6,
realPower7,
apparentPower7,
powerFactor7,
Irms7,
realPower8,
apparentPower8,
powerFactor8,
Irms8,
realPower9,
apparentPower9,
powerFactor9,
Irms9,
realPower10,
apparentPower10,
powerFactor10,
Irms10,
Vrms,
realPower,
Irms;
boolean settled = false;
int SupplyVoltage;
class Output
long OnTime; // milliseconds of on-time
long OffTime; // milliseconds of off-time
unsigned long previousMillis; // will store last time LED was updated
public:
Output(long on, long off)
OnTime = on;
OffTime = off;
previousMillis = 0;
void Update()
if((currentMillis - previousMillis >= OnTime))
previousMillis = currentMillis; // Remember the time
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT1,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms1); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT2,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms2); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT3,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms3); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT4,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms4); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT5,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms5); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT6,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms6); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT7,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms7); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT8,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms8); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT9,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms9); Serial.print(","); Serial.println(powerFactor5);
Serial.print(rtc.getUnixTime(rtc.getTime())); Serial.print(","); Serial.print("PU1,1Ph-CT10,"); Serial.print(Vrms); Serial.print(","); Serial.print(Irms10); Serial.print(","); Serial.println(powerFactor5);
class Sdwrite
int increment;
int updateInterval; // interval between updates
unsigned long lastUpdate; // last update of position
public:
Sdwrite(long int interval)
updateInterval = interval;
increment = 1;
I have break this code in posting for message exceed..
void Update()
if((millis() - lastUpdate) > updateInterval) // time to update
lastUpdate = millis();
if (dataFile) {
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.println();
dataFile.close();
Output output(100,100);
Sdwrite sdwrite(60000);
// enable software serial
rtc.begin();
pinMode(2,OUTPUT);
pinMode(6,OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
delay(9000);
if (!settled && millis() > FILTERSETTLETIME) settled = true;
if (settled)
// Outer loop - Reads Voltages & Currents - Sends results
calcVI3Ph(11,2000); // Calculate all. No.of complete cycles, time-out
output.Update();
sdwrite.Update();
void calcVI3Ph(int cycles, int timeout)
int SupplyVoltage = readVcc();
//Serial.print("SupplyVoltage"); Serial.println(SupplyVoltage);
int crossCount = 0; // Used to measure number of times threshold is crossed.
int numberOfSamples = 0; // This is now incremented
int numberOfPowerSamples = 0; // Needed because 1 cycle of voltages needs to be stored before use
boolean lastVCross, checkVCross; // Used to measure number of times threshold is crossed.
double storedV[PHASE3]; // Array to store >120 degrees of voltage samples
// 1) Waits for the waveform to be close to 'zero' (500 adc) part in sin curve.
boolean st=false; // an indicator to exit the while loop
unsigned long start = millis(); // millis()-start makes sure it doesnt get stuck in the loop if there is an error.
while(st==false) // Wait for first zero crossing...
digitalWrite(6,LOW);
//delay(2);
digitalWrite(2,LOW);
//delay(2);
startV = analogRead(inPinV); // using the voltage waveform
digitalWrite(6,HIGH);
if ((startV < 550) && (startV > 440)) st=true; // check it's within range
if ((millis()-start)>timeout) st = true;
// 2) Main measurment loop
start = millis();
while ((crossCount < cycles * 2) && ((millis()-start)<timeout))
lastSampleV=sampleV; // Used for digital high pass filter - offset removal
lastSampleI1=sampleI1;
lastSampleI2=sampleI2;
lastSampleI3=sampleI3;
lastSampleI4=sampleI4;
lastSampleI5=sampleI5;
lastSampleI6=sampleI6;
lastSampleI7=sampleI7;
lastSampleI8=sampleI8;
lastSampleI9=sampleI9;
lastSampleI10=sampleI10;
lastFilteredV = filteredV;
lastFilteredI1 = filteredI1;
lastFilteredI2 = filteredI2;
lastFilteredI3 = filteredI3;
lastFilteredI4 = filteredI4;
lastFilteredI5 = filteredI5;
lastFilteredI6 = filteredI6;
lastFilteredI7 = filteredI7;
lastFilteredI8 = filteredI8;
lastFilteredI9 = filteredI9;
lastFilteredI10 = filteredI10;
// A) Read in raw voltage and current samples
//delay(2);
//delay(2);
sampleV = analogRead(inPinV);
sampleI1 = analogRead(inPinI1); // Read in raw current signal
sampleI2 = analogRead(inPinI2); // Read in raw current signal
sampleI3 = analogRead(inPinI3); // Read in raw current signal
sampleI4 = analogRead(inPinI4); // Read in raw current signal
sampleI5 = analogRead(inPinI5); // Read in raw current signal
digitalWrite(2,HIGH);
//delay(2);
sampleI6 = analogRead(inPinI6); // Read in raw current signal
sampleI7 = analogRead(inPinI7); // Read in raw current signal
sampleI8 = analogRead(inPinI8); // Read in raw current signal
sampleI9 = analogRead(inPinI9); // Read in raw current signal
sampleI10 = analogRead(inPinI10); // Read in raw current signal
// B) Apply digital high pass filters to remove 2.5V DC offset (to centre wave on 0).
filteredV = 0.996*(lastFilteredV+sampleV-lastSampleV);
filteredI1 = 0.996*(lastFilteredI1+sampleI1-lastSampleI1);
filteredI2 = 0.996*(lastFilteredI2+sampleI2-lastSampleI2);
filteredI3 = 0.996*(lastFilteredI3+sampleI3-lastSampleI3);
filteredI4 = 0.996*(lastFilteredI4+sampleI4-lastSampleI4);
filteredI5 = 0.996*(lastFilteredI5+sampleI5-lastSampleI5);
filteredI6 = 0.996*(lastFilteredI6+sampleI6-lastSampleI6);
filteredI7 = 0.996*(lastFilteredI7+sampleI7-lastSampleI7);
filteredI8 = 0.996*(lastFilteredI8+sampleI8-lastSampleI8);
filteredI9 = 0.996*(lastFilteredI9+sampleI9-lastSampleI9);
filteredI10 = 0.996*(lastFilteredI10+sampleI10-lastSampleI10);
storedV[numberOfSamples%PHASE3] = filteredV; // store this voltage sample in circular buffer
if (crossCount > 2) // one complete cycle has been stored, so can use delayed
{ // voltage samples to calculate instantaneous powers
// C) Root-mean-square method voltage
sqV= filteredV * filteredV; //1) square voltage values
//Serial.print(" Squared Volt"); Serial.println(sqV);
sumV += sqV; //2) sum
//Serial.print(" Squared sum"); Serial.println(sumV);
// D) Root-mean-square method current
sqI1 = filteredI1 * filteredI1; //1) square current values
sumI1 += sqI1; //2) sum
sqI2 = filteredI2 * filteredI2;
sumI2 += sqI2;
sqI3 = filteredI3 * filteredI3;
sumI3 += sqI3;
sqI4 = filteredI4 * filteredI4;
sumI4 += sqI4;
sqI5 = filteredI5 * filteredI5;
sumI5 += sqI5;
sqI6 = filteredI6 * filteredI6;
sumI6 += sqI6;
sqI7 = filteredI7 * filteredI7;
sumI7 += sqI7;
sqI8 = filteredI8 * filteredI8;
sumI8 += sqI8;
sqI9 = filteredI9 * filteredI9;
sumI9 += sqI9;
sqI10 = filteredI10 * filteredI10;
sumI10 += sqI10;
// E) Phase calibration - for Phase 1: shifts V1 to correct transformer errors
// for phases 2 & 3 delays V1 by 120 degrees & 240 degrees respectively
// and shifts for fine adjustment and to correct transformer errors.
phaseShiftedV1 = lastFilteredV + Phasecal1 * (filteredV - lastFilteredV);
//Serial.print(" Phase corrected Volt"); Serial.println(phaseShiftedV1);
phaseShiftedV2 = storedV[(numberOfSamples-PHASE2-1)%PHASE3]
  • Phasecal2 * (storedV[(numberOfSamples-PHASE2)%PHASE3]
  • storedV[(numberOfSamples-PHASE2-1)%PHASE3]);
    phaseShiftedV3 = storedV[(numberOfSamples+1)%PHASE3]
  • Phasecal3 * (storedV[(numberOfSamples+2)%PHASE3]
  • storedV[(numberOfSamples+1)%PHASE3]);
// F) Instantaneous power calc
instP1 = phaseShiftedV1 * filteredI1; //Instantaneous Power
sumP1 +=instP1; // sum
instP2 = phaseShiftedV1 * filteredI2;
sumP2 +=instP2;
instP3 = phaseShiftedV1 * filteredI3;
sumP3 +=instP3;
instP4 = phaseShiftedV1 * filteredI4;
sumP4 +=instP4;
instP5 = phaseShiftedV1 * filteredI5;
sumP5 +=instP5;
instP6 = phaseShiftedV1 * filteredI6;
sumP6 +=instP6;
instP7 = phaseShiftedV1 * filteredI7;
sumP7 +=instP7;
instP8 = phaseShiftedV1 * filteredI8;
sumP8 +=instP8;
instP9 = phaseShiftedV1 * filteredI9;
sumP9 +=instP9;
instP10 = phaseShiftedV1 * filteredI10;
sumP10 +=instP10;
numberOfPowerSamples++; //Count number of times looped for Power averages.
// G) Find the number of times the voltage has crossed the initial voltage
// - every 2 crosses we will have sampled 1 wavelength
// - so this method allows us to sample an integer number of half wavelengths which increases accuracy
lastVCross = checkVCross;
if (sampleV > startV)
checkVCross = true;
checkVCross = false;
if (numberOfSamples==1)
if (lastVCross != checkVCross)
crossCount++;
numberOfSamples++; //Count number of times looped.
// 3) Post loop calculations
//Calculation of the root of the mean of the voltage and current squared (rms)
//Calibration coefficients applied.
double V_Ratio = Vcal *((SupplyVoltage/1000.0) / 1023.0);
Vrms = V_Ratio * sqrt(sumV / numberOfPowerSamples);
double I_Ratio1 = Ical1 *((SupplyVoltage/1000.0) / 1023.0);
Irms1 = I_Ratio1 * sqrt(sumI1 / numberOfPowerSamples);
double I_Ratio2 = Ical2 *((SupplyVoltage/1000.0) / 1023.0);
Irms2 = I_Ratio2 * sqrt(sumI2 / numberOfPowerSamples);
double I_Ratio3 = Ical3 *((SupplyVoltage/1000.0) / 1023.0);
Irms3 = I_Ratio3 * sqrt(sumI3 / numberOfPowerSamples);
double I_Ratio4 = Ical4 *((SupplyVoltage/1000.0) / 1023.0);
Irms4 = I_Ratio4 * sqrt(sumI4 / numberOfPowerSamples);
double I_Ratio5 = Ical5 *((SupplyVoltage/1000.0) / 1023.0);
Irms5 = I_Ratio5 * sqrt(sumI5 / numberOfPowerSamples);
double I_Ratio6 = Ical6 *((SupplyVoltage/1000.0) / 1023.0);
Irms6 = I_Ratio6 * sqrt(sumI6 / numberOfPowerSamples);
double I_Ratio7 = Ical7 *((SupplyVoltage/1000.0) / 1023.0);
Irms7 = I_Ratio7 * sqrt(sumI7 / numberOfPowerSamples);
double I_Ratio8 = Ical8 *((SupplyVoltage/1000.0) / 1023.0);
Irms8 = I_Ratio8 * sqrt(sumI8 / numberOfPowerSamples);
double I_Ratio9 = Ical9 *((SupplyVoltage/1000.0) / 1023.0);
Irms9 = I_Ratio9 * sqrt(sumI9 / numberOfPowerSamples);
double I_Ratio10 = Ical10 *((SupplyVoltage/1000.0) / 1023.0);
Irms10 = I_Ratio10 * sqrt(sumI10 / numberOfPowerSamples);
//Calculation power values
realPower1 = V_Ratio * I_Ratio1 * sumP1 / numberOfPowerSamples;
apparentPower1 = Vrms * Irms1;
powerFactor1 = realPower1 / apparentPower1;
realPower2 = V_Ratio * I_Ratio2 * sumP2 / numberOfPowerSamples;
apparentPower2 = Vrms * Irms2;
powerFactor2 = realPower2 / apparentPower2;
realPower3 = V_Ratio * I_Ratio3 * sumP3 / numberOfPowerSamples;
apparentPower3 = Vrms * Irms3;
powerFactor3 = realPower3 / apparentPower3;
realPower4 = V_Ratio * I_Ratio4 * sumP4 / numberOfPowerSamples;
apparentPower4 = Vrms * Irms4;
powerFactor4 = realPower4 / apparentPower4;
realPower5 = V_Ratio * I_Ratio5 * sumP5 / numberOfPowerSamples;
apparentPower5 = Vrms * Irms5;
powerFactor5 = realPower5 / apparentPower5;
realPower6 = V_Ratio * I_Ratio6 * sumP6 / numberOfPowerSamples;
apparentPower6 = Vrms * Irms6;
powerFactor6 = realPower6 / apparentPower6;
realPower7 = V_Ratio * I_Ratio7 * sumP7 / numberOfPowerSamples;
apparentPower7 = Vrms * Irms7;
powerFactor7 = realPower7 / apparentPower7;
realPower8 = V_Ratio * I_Ratio8 * sumP8 / numberOfPowerSamples;
apparentPower8 = Vrms * Irms8;
powerFactor8 = realPower8 / apparentPower8;
realPower9 = V_Ratio * I_Ratio9 * sumP9 / numberOfPowerSamples;
apparentPower9 = Vrms * Irms9;
powerFactor9 = realPower9 / apparentPower9;
realPower10 = V_Ratio * I_Ratio10 * sumP10 / numberOfPowerSamples;
apparentPower10 = Vrms * Irms10;
powerFactor10 = realPower10 / apparentPower10;
//Normalising current & power
if(Irms1 <0.3) { Irms1=0; realPower1=0; powerFactor1=0;}
if(Irms2 <0.3) { Irms2=0; realPower2=0; powerFactor2=0;}
if(Irms3 <0.3) { Irms3=0; realPower3=0; powerFactor3=0;}
if(Irms4 <0.3) { Irms4=0; realPower4=0; powerFactor4=0;}
if(Irms5 <0.3) { Irms5=0; realPower5=0; powerFactor5=0;}
if(Irms6 <0.3) { Irms6=0; realPower6=0; powerFactor6=0;}
if(Irms7 <0.3) { Irms7=0; realPower7=0; powerFactor7=0;}
if(Irms8 <0.3) { Irms8=0; realPower8=0; powerFactor8=0;}
if(Irms9 <0.3) { Irms9=0; realPower9=0; powerFactor9=0;}
if(Irms10 <0.3) { Irms10=0; realPower10=0; powerFactor10=0;}
Irms = (Irms1 + Irms2 + Irms3)/3;
realPower = 1.73 * Vrms * Irms * powerFactor1;
//Reset accumulators
sumV = 0;
sumI1 = 0;
sumI2 = 0;
sumI3 = 0;
sumI4 = 0;
sumI5 = 0;
sumI6 = 0;
sumI7 = 0;
sumI8 = 0;
sumI9 = 0;
sumI10 = 0;
sumP1 = 0;
sumP2 = 0;
sumP3 = 0;
sumP4 = 0;
sumP5 = 0;
sumP6 = 0;
sumP7 = 0;
sumP8 = 0;
sumP9 = 0;
sumP10 = 0;
long readVcc() {
ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); // for ADK
/ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1); //for UNO/
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Start conversion
while (bit_is_set(ADCSRA,ADSC)); // measuring
uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
uint8_t high = ADCH; // unlocks both
long result = (high<<8 ) | low;
result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.110231000
return result; // Vcc in millivolts */
c) You used code tags, or attached you code if (as appears to be the case), the bloated code exceeds the posting limit.
