Help programming POV Globe
Hello, I need somebody please help me in this project (in programming):
https://code.google.com/p/povglobe/
What happens is that I already finished the Hardware but in the programming part I have some problems.
As you will see in:
Source/Browse/svn/trunk/GlobePOV (Here also are images of the globe, pumpkin, test, etc.)
You can find the project schedule (GlobePOV.pde) and other necessary files that must to be moved to the include folder of arduino (ARDUINO / hardware / tools / avr / avr / include /) to compile the program. You can find the project schedule (GlobePOV.pde) and other necessary files that must to be moved to the include folder of arduino (ARDUINO / hardware / tools / avr / avr / include /) to compile the program. I need someone who explain to me how to put the images that you want to see (such as the globe, pumpkin, test, etc). I forget say that WProgram.h should be changed by Arduino.h .Thanks
Hi, how is your project right now? HAHA! Same here, I've built already the hardware part, the whole body is already functioning but the codes don't seem to work. Well, I tried the revision #2 and the arduino accepted it, but all the leds are on all the time, no display.
Mr. Ben (the maker of the project) has noted in his revision # 19 that it is a good working globe. But nahh, the Wprogram.h header is missing and after all these 5 years, he didn't reply. sad.
Now, I only have 1 or 2 weeks to finish the project, and I'm afraid if he won't reply to my email... I will be forced to make my own codes using multiplexing and shift registers.
glenn
