Help random number
Hi I want to do a random list I need that 13 numbers have a random behaviour each time I turn on my Arduino - I'm a visual artist and I don't have a lot of experience programming I was going to program it with something like this
randNumber1 = random(13);
randNumber2 = random(13);
randNumber3 = random(13);
randNumber4 = random(13);
randNumber5 = random(13);
randNumber6 = random(13);
randNumber7 = random(13);
randNumber8 = random(13);
randNumber9 = random(13);
randNumber10 = random(13);
randNumber11 = random(13);
randNumber12 = random(13);
randNumber13 = random(13);
if (randNumber1 = randNumber2)
if (randNumber1 = randNumber3)
if (randNumber1 = randNumber4)
if (randNumber1 = randNumber5)
if (randNumber1 = randNumber6)
if (randNumber1 = randNumber7)
if (randNumber1 = randNumber8)
if (randNumber1 = randNumber9)
if (randNumber1 = randNumber10)
if (randNumber1 = randNumber11)
if (randNumber1 = randNumber12)
if (randNumber1 = randNumber13)
And so it with each randNumber but I'm sure there is a easier more productive way to do it , can anyone help me
Thanks
I am guessing you don't want duplicated numbers?
#define TOTAL_NUMBERS 13
int n[TOTAL_NUMBERS];
  randomSeed(analogRead(0));
  // Fill initial values
  for(int i=0;i<TOTAL_NUMBERS;i++)
    n[i]=i+1;
  // Randomize (swaping)
  int p1, p2, v;
    p1 = random(TOTAL_NUMBERS);
    p2 = random(TOTAL_NUMBERS);
    v = n[p1];
    n[p1] = n[p2];
    n[p2] = v;
  // Use random numbers here n[0-TOTAL_NUMBERS]
You are a genius tks tks tks
const int totalNumbers = 13;
int randnums[totalNumbers];
  int availablenumbers[totalNumbers];
  for (int i=0; i< totalNumbers; i++) {
    availablenumbers[i] = i+1;
  for (int i=totalNumbers; i>=0; i++) {
    int n = random(i);
    randnums[i] = availablenumbers[n];
    for (int j = n; j < i-1; j++) {
      availablenumbers[j] = availablenumbers[j+1];
here's another idea that may or may not work.
Wanderson has a nice random number generator that seems to work well. I had occasion to run some test's for him and it worked well on 2 Uno's a Mega and 2 Pro Mini's.
Doc
eried's approach optimized,
no need to swap two random elements as you can swap over loop iterations. which is faster (however as it is only executed in setup it is no big deal)
  for (int i=0; i< totalNumbers; i++) randnums[i] = i+1;
  int freeslot = 0;
    int n = random(totalNumbers);
    randnums[freeslot] = randnums[n];
    freeslot = n;
  randnums[freeslot] = 1;
NOte: the Arduino will allways give the same sequences with the random function - random() - Arduino Reference -
I'm guessing that was unintentional.
