Help reading a number over serial?
I wanted a simple control of voltage over USB serial, where i type in a number in the serial moniter and it sets that number to the pin, but i know that the serial is sending the ascii numbers or something... anyway here's my code.
void setup(void) {
// initialize inputs/outputs
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
int val;
digitalWrite(8,LOW);
digitalWrite(10,LOW);
// begin the serial communication
int val;
val == 0;
if (Serial.available()) {
val = Serial.read();
analogWrite(9, val);
analogWrite(11, val);
delay(200);}
Serial.print(val);
Is there any way to get it so that i type 225 into a serial program and it sends that value to the board?
Thanks in advance, Cybot.
Try something like this:
// code for receiving a value followed by a letter
// that writes the value to an analog pin corrosponding to that letter
int analogPins[] = {3, 5, 6, 9, 10, 11};  // 'a','b','c','d','e','f'
  serviceSerial();
// serviceSerial expects data in the form:
// "255a"  - analog writes 255 to pin 3
// "127c"  - analog writes 127 to pin 6
// "0f"    - analog writes 0 to pin 11
void serviceSerial()
  static int val = 0;
  if ( Serial.available()) {
    char ch = Serial.read();
    if(ch >= '0' && ch <= '9')              // is ch a number?
      val = val * 10 + ch - '0';            // yes, accumulate the value
    else if(ch >= 'a' && ch <= 'f'){        // is ch a letter for one of the analog pins?
       int pin = analogPins[ch - 'a'];      // use the letter to index into the pin array
       analogWrite(pin, val);               // write the previously received val to the pin
sending a value followed by a letter writes the value to an analog pin corrosponding to the letter :
send: “255a” to analog writes 255 to pin 3
send “127c” to analog writes 127 to pin 6
send: “0f” to analog write 0 to pin 11
I have not run the code but it should get you going in the right direction.
Have fun!
works better but it isnt writing the value i give it, eg i think that when i send 450d it write 200 to pin 9...
try setting val to 0 after the pin identifer is received
you may also want to add some print statments immediatly after the analogWrite
   analogWrite(pin, val); // the exisiting analogWrite statement
   Serial.print(pin,DEC);
   Serial.print("->");
   Serial.println(val,DEC);
   val = 0;
edit: added suggestion to reset val to 0
when i send 450d
450 is out of the legal range of 0-255 (decimal). You'll need to either add some error-checking and reject numbers greater than 255, or accept that the code will truncate the number to 8 bits.
Now that makes sence, Thanks for all your help!
